Thread: control indicator lights on
    inverness
    Default control indicator lights on
    hi all new to this site just bought a vectra c dti 2 ltr and was traveling up motor way and the control indicator light came on had v6 few years ago and used to do a paper clip test just wondering if ou can do it on these cars and where the socket is for pluging in the tech computer in if need be
    or does anyone know what the problem could be it comes on when i put the foot down and i lose power and get put down to 60 mph confuse if any one can help it will be very helpful cheers to all matt
    You can't do the paper clip test any more, on the dti the fav fault is holes in the boost pipes.
    HTH
    inverness
    Thumbs down
    expensive to repair i take it
    No not really. have a look around the engine bay and check all the hoses for splits etc. It may not be that, it could be the boost pressure sensor that needs cleaning, another dit fav. Do a search as I know there are some pics etc on here
    inverness
    wicked mate ill have a look on here see if i can find anything any other problems to watch out for that you know of,,what best key words to search
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    HTH
    It is even easier now to get fault codes to blink out....
    Press and hold brake pedal and accelerator pedal to floor, turn on ignition to pos 2, release acc pedal and then re-apply, then turn ignition switch off and back to pos 2 keeping both brake and acc pedals down.
    After a short pause the engine symbol blinks out the codes in the normal format.
    It works for my 04 1.8 LS
  1. Control indicator for exhaust
    By Dazr82 in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2011, 23:30
  2. Cruise control indicator
    By 111 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2010, 12:49
  3. 3.2 V6 control indicator light
    By ozziemokuy in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2010, 14:33
  4. Control indicator for the exhaust...
    By johnny in forum Engine & Drivetrain
    Last Post: 25th January 2008, 22:32
  5. Exhaust Control Indicator
    By D-S-Dave in forum Engine & Drivetrain
    Last Post: 30th December 2007, 22:57
