Thread: How to re-wire a plug...
    Northampton, UK
    Default How to re-wire a plug...
    Stupid Q and as I know there are a lot of clever people on here...
    Can I re-wire one of these plugs - LINKY in to a standard UK 3 prong plug?
    Like a dunce I bought something and didnt even think that it may have a non UK standard plug!
    Regular Member Robbie69's Avatar
    I'm not certain but it should be ok, what voltage does it run on? It's a standard euro plug. I can't see why you can't just rewire it.
    Robbie
    Northampton, UK
    Cool, I have no idea what voltage it runs on, it says 220 on the box, but the plug says 250...?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    it will work m8 as i had a grinder with that plug on it and we changed it and it was fine
    Regular Member adfrodsham's Avatar
    lincoln
    you should be able to, once you cut the wire there should be a earth inside, i did my philips euro plugs, if its something of quality then yes you should be able to as will have earth, if its something cheap proberly no earth
    Full Member spennny's Avatar
    Blantyre
    Yes, you can mate, when we returned from DE , i had ti change all plugs over,
    And we still have the mixer to do, and it says the same as you mention above
    16 miles outside Belfast
    Yeah you can change it no probs. Just cut off the euro plug I see it appears to be a sealed plug and then wire up the new one as normal.
    Live = Brown
    Neutral = Blue
    Earth = Green/Yellow
    The 220V will work fine in the UK.
    (Electrician by trade) though the credit crunch saw an end to that LOL
    [Ex]Admin Duncan's Avatar
    As already said Nick, shouldn't be a problem. The 'blank hole' on the plug is for the earth which is a prong on the socket so if the appliance needs earthed then you'll find that wire inside the cable once the plug is chopped off.
    Quote Originally Posted by adfrodsham View Post
    y..if its something of quality then yes you should be able to as will have earth, if its something cheap proberly no earth
    It's not dependent on whether it's a cheap item or not. If it needs an earth then it will be wired accordingly. If it's double insulated then there won't be an earth wire in the cable, just the live and neutral so only those two need to, or can be, wired up to the new plug.
  1. Speaker wire plug adaptor
    By wright8672 in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2013, 18:55
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. what does this wire/plug do?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2011, 20:11
  4. blue plug display into a grey plug vehicle
    By vxpenfold in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 23:09
  5. grey plug yellow plug?
    By paul_sri150 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd May 2010, 14:35
