Results 1 to 10 of 15
Thread: Side light removal
    Newcastle under Lyme
    Default Side light removal
    How do I remove them. Ive looked at the How 2's but never claimed to have the best eyesight.
    If there isnt one Ill make one
    WGAF#5
    best way i found is to use the keyfob size tesco club card - slide it in behind the side light closest to the door and it should pop out
    bonus using the club card is that its plastic on plastic so no nasty scratches and the card is softer than the sidelight so gives and wont break the mount
    to refit if it persists in sitting proud do the above in reverse order
    hth
    regards
    Dez
    Any idea how to get the cable out. The drivers side came out fine the passenger side unclipped I pulled it out but they had obviously not clipped it on as the cable had come off prior to removal
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    lol, a bit of welding rod and fish it out....i take it you mean side repeaters....when i removed mine i tied rubber gloves onto the cable as soon as i saw it to stop it falling in
    It dednt even make it out the 1st one was fine the 2nd one fell off inside the wing. Cheers will get some earth cable. Not fairting my chances though im **** at fishing
    you get gripper things from places like b and Q, kindof grappling hook on a wire with a grab button at the end of it, you could try one of these
    COpper earth wire with a hook at the end did me just as good cheers
    Posted a how to for moderation
    How tinted can they go?
    i did enough to make mine the same as the trimline going along the car, and they are still visable..... tho they have faded slightly ( i didnt laquer them tho )
    Cool mine are almost black now and I didnt want them being unseen.
  1. N/side wing removal
    By stopi in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2012, 17:32
  2. Side airbag removal help
    By smitd004 in forum Bodywork & Interior
    Last Post: 21st April 2011, 10:14
  3. Side repeater removal
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2007, 10:24
