Results 1 to 10 of 14
Thread: Headlamp Washer Question
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Default Headlamp Washer Question
    Okay ive got a parts list for it but ive just looked and i dont have the Wiring!! but i do have the relay and the fuse....weird. ive got the wiring for the sensor which is good as i want a GID but thats a differnt story.
    is there a way of hooking the wiring in? or will i just have to take the feed off the window washer one? so i get them come on when i wash the windows? its annoying as i want them so i can use my HID's on public roads as i only use them on private roads of cource
    lol i hope all of this makes sence!
    No idea if you can just piggy-back the window washers mate as I'm not a leccy, but if you take the feed from the relay itself it'll still need tech2ing to activate them...
    ahh its worth a go before i link it to the relay then i suppose. whats the worse it can do exept throw up a error code? lol there low voltage anyway so its not going to burn out the wiring!
    cambs
    hi
    yes you can wire it up m8
    i have done this myself and you will need it to be tech2'd after.
    cambs
    hi me again
    just had a look and you need a wire from pin 26 from XE2.
    undo the fuse box and remove and its the connector at the top closest to the windscreen.
    and put the wire to the hole on the right next to the screw hole.
    okay once ive done that is the other side of the plug the earth then? and will i have to wire anything else up from the relay as my TIS gives me a picture of it all so i understand what you mean at the moment but is it just a case of XE2 plug 26. sticking a wire on that sticking that into the pump connector and then the other pump wire is to earth? i hope it is that simple....lol im probbly explaining it is a really difficult way!
    cambs
    Quote Originally Posted by redraptor_141 View Post
    yes m8 earth sorry missed that out.
    it goes to the earth point next to the fuse box on the wing.
    Thats Brill thanks. another jobbie to add to the list lol
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    as said it can be retrofitted did the same to mine. with help from andy.l
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Quote Originally Posted by mhvcbv View Post
    hi
    you got your's working now then mate....mine are a little weird, have all the loom there and tech2'd on but still not working...
    Midlands Mod Shop - NFFC.
  1. For Sale: Facelift Headlamp Washer Kit
    By leeds vectra in forum Parts for sale
    Last Post: 27th September 2011, 19:52
  2. Headlamp washer covers..
    By ROY2593 in forum Parts for sale
    Last Post: 14th February 2009, 22:32
  3. pre-facelift headlamp washer kit
    By andy.l in forum Parts for sale
    Last Post: 22nd December 2007, 20:25
