Results 1 to 10 of 13
Thread: autolocking problem
    Feb 2006
    newcastle
    Default autolocking problem
    hi
    i did the auto locking mod some time ago and it worked a treat until i dropped the hammer on my key, which then broke the buttons, i have tried the mod with my spare key but it does not work.
    i then put the original key in the ignition and drove away, it auto locked. so the auto lock must be linked to the key but i need to deactivate the key that is bust so i can activate the spare to auto lock,
    any ideas?
    john
    Blantyre
    Cant you use the spare to drive ? Would this not activate the key, or re=do the mod using the spare key ??
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Quote Originally Posted by spennny View Post
    As he said try and use spare key bud
    Feb 2006
    newcastle
    nope it does not work i have tried with the spare key to do the mod, it works the car ok but not the auto lock, it even makes the faint beep but no joy.
    the only way i see it i need to try and deactivate the broken key so its back to normal then use the spare to auto lock
    john
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    it is true that it is programmed into the key, but you can program each key
    try again with the spare key without the first one being around
    Newcastle under Lyme
    swap the transpoder to the spare key iff possible?
    Blantyre
    disconnect the battery for 30 mins..............maybe
    11 Post(s)
    Try switching off the autolocking with the spare key, then re-activating it.
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    program each key to do auto-locking m8
    Regular Member bertbuckie1's Avatar
    Turriff - Aberdeenshire
    remember to turn on autolocking it must beep twice faintly, not once!!!!
  1. Taxi Doors / Autolocking Doors
    Last Post: 17th April 2012, 19:05
  2. Autolocking after 30 secs
    By carlton in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2009, 21:25
  3. Another autolocking question...
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2008, 21:06
  4. How to disable 30 second Autolocking??
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2006, 16:54
