Results 1 to 10 of 11
Thread: Airbox Mod
    Regular Member KSD's Avatar
    Aug 2007
    Cupar, Fife
    Default Airbox Mod
    Come on, convince me to do the airbox mod, Im reluctant at the mo because of an issue with my previous Vectra (1.8 LS, no difference felt and acute emissions failure!)
    Now got 1.8 SRi, so tell me the pros and maybe cons of doing mod, might do it tomorrow if all goes well.
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    smoother pick up and better fuel econamy, is yours the vvt engine you have now
    Aug 2007
    Cupar, Fife
    Quote Originally Posted by davidjameswest View Post
    Aye mate 1.8 vvti
    llantwit major
    well all i sugest is try and see if you get the mod, if not you wont affect any thing with allowing more air into the box as its measured by the mass air flow to put the correct amount in but if you boot it you will have the unrestricted flow should you need it , if you dont like it put the piece back on
    Newcastle under Lyme
    If you dont like it put it back on - You dont snap it off it has clips either side and although it needs a little force and seems like you will break it - it will slot back in
    Aug 2007
    Cupar, Fife
    Quote Originally Posted by JSYSH466Y View Post
    Right enough, might give it a trial, will let yous know, cheers
    llantwit major
    no worries
    Regular Member Readster's Avatar
    Plymouth
    I have done the mod and am happy knowing that all the air filter is being used now.
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    better pick up in lower gears bud no difference to bhp better a lot smoother take off also done it my boy's 1.6 sxi astra he feels the difference in the lower gear range also.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Mine's possibly a bit punchier higher up the rev range @3500+. The only downside is increased noise at tickover.
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
