Results 1 to 10 of 23
Thread: whistling noise
    eng
    Default whistling noise
    just bough 55 plate vectra 150 sri, i just started realising a whistling noise that happens when i start accelerating then slowly going off when i deccelerate what can this be?
    Regular Member Robbie69's Avatar
    The turbo? Or an excited parrot?
    WGAF#5
    Quote Originally Posted by fizler316 View Post
    suspect you have a hole or split in one of your air pipes or maybe a loose jubilee clip get someone to rev the engine with the bonnet up - should be able to locate it from that
    eng
    is it a expensive problem to fix if its the turbo or whole in the air pipes
    Regular Member Marc Hutton's Avatar
    Edinburgh/Catterick
    Turbo m8
    eng
    how much am i looking at to repair it cos i just bought the car
    Vale of Glamorgan
    I heard a similar noise after I did the airbox mod, assumed it was due to that but may have to check the hoses now,
    Apr 2009
    Norwich, UK
    Quote Originally Posted by Marc Hutton View Post
    Turbo m8
    I hope that's not the case. I noticed mine this morning, but I thought that moise was common on a turbo engine. Only had this car a week. However, I have a Network Q warranty, so no worries yet.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by rogerp View Post
    wistle+wheezes are common for cdti 150 its turbo pressure, it should come and go as you change up nothing to worry about unless its louder than the radio!!!!
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    mine makes that noise when cold but goes on warm
  1. What is that whistling noise....
    By baldieone in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 10:15
  2. whistling noise
    By rick1965 in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2010, 21:06
  3. Whistling Noise When Revving
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 26th November 2008, 10:23
  4. squealing/whistling noise
    By cholly69 in forum Engine & Drivetrain
    Last Post: 30th August 2008, 08:29
  5. v6 vectra b whistling noise
    By listerd in forum General Chat
    Last Post: 31st July 2007, 19:50
