Thread: Immobiliser Loses Code
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Immobiliser Loses Code
    Hey all,
    I've got the RIGHT HUMP!! My 2002 Vectra C is losing it's code on the immobiliser and will not start. I've had it with a mechanic all week who sorted it, left it for 24hrs and now again, it won't start.
    He's gonna speak to VX tomorrow fo rsuggestions, but has anyone had this issue? It turns over but doesn't fire, nor does anything on the dash flash as I'm told it should. It's switching the fuel pump off.
    Can ANYONE out there help?
    Administrator plasma's Avatar
    On the Forum
    410 Post(s)
    Engine : 150
    Mileage : 74000
    your getting the padlock symbol coming up?
    WGAF#5
    need to establish if its the key not programmed correctly or the immobiliser ecu not recieving the information
    Bristol
    If the immobiler causing the problem the car would not turn over. You will have a lock comming up in the dash.
    Apr 2009
    Stevenage, Herts
    The padlock symbol does not illuminate at all. He's recoded it once this week somehow, and it again worked for a couple of days then last nght won't start!
    The keyfob is an opel one the previous onwer got whilst out in poland, I doubt that would matter would it?
    Bristol
    no if it programed correctly if it was not you could not open doors remotly or turn the engine over. I think you have a fuel pump problem.
    Glasgow
    I had the same problem recently but would'nt start at all and got towed to VX, the problem was in the tank on the pump a loose fuel line i believe.
  1. Elegance loses power
    By Tinks in forum Engine & Drivetrain
    Last Post: 20th July 2012, 19:34
  2. US loses second aircraft
    By m8internet in forum The 'Off Topic' room
    Last Post: 14th August 2011, 09:26
  3. CDC40 Opera Loses Stored Stations !!!
    By DeanF in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2010, 19:52
  4. Hamilton loses Aussie GP points
    By Tadpole in forum Motorsport / Formula 1 etc. chat
    Last Post: 7th April 2009, 19:48
  5. Silverstone loses F1
    By Ian T in forum Motorsport / Formula 1 etc. chat
    Last Post: 5th July 2008, 12:32
