Results 1 to 10 of 30
Thread: Help - can't undo locking nuts/how do you remove spinning collar?
    Regular Member nigec's Avatar
    barnsley
    Default Help - can't undo locking nuts/how do you remove spinning collar?
    Just been to frauds for my caliper paint and cleaner, got back home so i thought id remove a wheel and have a look. Thought id loosen nuts ready for jacking, but this useless locking nut is breaking what a joke !! do i need to order anouther, will the same happen ? shall i take it to steelers and tell them how crap it is ? can they get these locking nuts off etc ?
    Has anyone else had these problems and are these problems covered under warrenty, help will be appreciated thanks.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    loads of em smash mate,, dealers will charge you sorry..
    Full Member spennny's Avatar
    Blantyre
    Have you had new tyre's recently, maybe they were done up with an air gun, which is a
    If yes take it back to the tyre place and ask them to remove
    Plymouth
    If its not broke yet... then the way i got it off was
    X2 Men...
    x1 4ft scaffolding pole
    One holds the locking nut and bar flush onto the bolt...
    The other slides the 4ft scaffolding pole over the bar and slowly inches it off...
    Then replace with non vx Locking nuts.
    Hth
    barnsley
    only had car 3 weeks !!
    Plymouth
    Quote Originally Posted by nigec View Post
    if bought from a garage take it back to them and tell them to remove um and replace with non Vx Parts
    barnsley
    it was from a non vx garage over at scunny though !!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    when the alloy wheel gets hot and then cools down the wheel nut sticks itself to the wheel aswell as been over tightened
    Regular Member garvey's Avatar
    Co Durham
    happenend to me.
    Newcastle under Lyme
    for the future ask them to grease your nuts when your wheels are removed
    Road grime can sometimes digress into the bolt threads when driving and make them very hard to remove even for non lockers. Buy a breaker bar from a place like halfords for about £15 and these are like an extended ratchet used for just unlocking very tight bolts
  1. Help - Remove locking wheels nuts of 2007 SRI
    By SteveBray in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 15:37
  2. VX Locking nuts?
    By keith1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2009, 12:49
  3. Locking Nuts
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2008, 00:54
  4. vx locking nuts
    By topline in forum Parts for sale
    Last Post: 23rd November 2006, 10:44
how to remove a locking wheel nut with spinning collar
how to remove spinning collar wheel nuts
how to remove spinning locking wheel nut
spinning collar wheel nut removal
spinning collar wheel lock removal
