Thread: New fan belt
    Jan 2008
    paisley
    Default New fan belt
    What should i expect to pay for a new fan belt (fitted) for a 2.0 dti with aircon? thanx
    Stockton on Tees
    The belt is about £20 plus VAT. VX would probably charge £100 to do it. A decent garage should do it for about £40. I paid £150 for belt and new crankshaft pulley fitted. It not a hard job to do yourself.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    go to a local motor factors m8, it should be about £12 and you can do this at home if you have a 15 or 17 mm spanner
    Jan 2008
    paisley
    thanx that is much less than i thought. Someone had told ne it was a bit of a job, that you had to remove the wheel arch to get access to it.
    Regular Member hmc_vectra's Avatar
    cupar fife
    draw a pic of where the belt gose first ok
    Stockton on Tees
    It is an easy enough job to do. HMC Vectra is right tho. Draw a pic. I never when i changed the belt on my old Vec B 2.0 DTi and spent ages trying different ways!! Removing the wheel and archmakes it easier but i did it without but it is a squeeze.
    Quote Originally Posted by nlporteous View Post
    remove the air box, easy
  1. 1.9 cam belt
    By J P S in forum Engine & Drivetrain
    Last Post: 18th February 2012, 12:13
  2. Belt changes on a 1.8 VVT
    By PeterVV in forum Engine & Drivetrain
    Last Post: 27th April 2011, 21:53
  3. Fan belt / Drive belt
    By patdavis in forum Engine & Drivetrain
    Last Post: 8th January 2011, 00:39
  4. drive belt or fan belt
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2008, 10:23
  5. fan belt ??
    By arniedavo in forum Engine & Drivetrain
    Last Post: 10th September 2008, 01:16
