Results 1 to 10 of 17
Thread: Another new induction kit
    Regular Member Harro's Avatar
    Jan 2008
    York
    Default Another new induction kit
    Arrived today
    Bit of a green theme going on, gonna fit it tomorrow, how easy does the air box come out on the V6?
    Regular Member Robbie69's Avatar
    If it's anything like the other models, it's easy. Undo jubilee clip on top pipe, then pull airbox out, it's held in on rubber bungs. 2 minute job.
    Jan 2008
    York
    Cool, just need the weather to hold off.
    Regular Member david.aka.judas's Avatar
    Suffolk
    remember to heat shield though..lol
    Jan 2008
    York
    Quote Originally Posted by Judas View Post
    Any point, does it make a difference?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Harro View Post
    Massive difference, as too much heat contaminating airflow can reduce power.
    Suffolk
    without being rude.....
    if you dont know the answer to that statement - you shouldn't be messing with cone filters.
    you need to make sure you heat shield and improve the cold air feed.
    do you have the original cold feed that went to the oem air box?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    You wont see many of us with cone filters on mate. Ecotecs kick out some heat and your more likely to lose power TBH.
    Jan 2008
    York
    Yeah will be keeping the original air feed in place and routing another in there as well. First time fitting a cone filter. Had a Dbilas flowmaster on my last vectra, used a thermometer fitted in the filter to check air temp. Ran about 1 0C above outside air temp, even though the filter housing would get hot after going for a drive. They're probably the best thing to fit for performance (sealed kits) I just want to hear a bit more from the engine.
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    you cant beat the sound of an induction kit on a v6 mate
  1. K&N Apollo CIS Universal Induction Kit vs. K&N 57i Induction Kit
    By LAZZEE RARSE in forum Petrol Engine related
    Last Post: 26th July 2010, 22:13
  2. Induction kit
    By andyprice86 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 14:00
  3. new induction kit on :D
    By damadom in forum Petrol Engine related
    Last Post: 15th May 2009, 10:54
  4. Induction Kit
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2008, 23:17
  5. Induction kit or not?????
    By stubopvectra in forum Diesel Engine related
    Last Post: 22nd April 2008, 15:36
