Results 1 to 10 of 23
Thread: broken springs are a joke!
    Somerset
    Default broken springs are a joke!
    I really feel for you guys that have had this and am touching wood right now (not my own).
    What I dont understand is how this can happen and how often. Are people having this sorted as part of warrantees or are you forking out?
    I was down my local dealers yesterday talking to a master tech guy and he was mentioning it as if there was no problem or no real cause.... I confessed i had changed mine to aftermarket ones after vauxhall dismissed my warranty claim of knocking front suspension. When i removed the old springs, the coating on them was all pitted and the actual spring was damaged what caused this i thought, then as i looked at the strut mount bolts i could see that paint ect was on the bottom of the bolt. So under slow speed compression (when you get most travel) the spring was making contact with the bolts . Please tell me guys that you asked to see or keep your springs because it would be interesting to see if this was happening more often.
    When i looked at my new springs they were slightly wider and kept away from the bolts. Now i have nice smooth suspension, and a little less faith in vaux.
    WGAF#5
    Quote Originally Posted by styles997 View Post
    cheers for that mate - interesting find and one for STE to look into
    just one more question if your not touching your wood ........who's wood are you touching
    Somerset
    boom boom
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I looked at mine (which failed at the bottom) and didn't see any contact marks on the top, so mine wasn't hitting the bolts.
    Most appear to fracture at the bottom, about 1/2 a turn in, where is starts to change coil diameter.
    Somerset
    Are vaux paying for replacements because this sounds like a recall issue.... My dealership are saying that loads are failing and people are forking out. Even for 1 at a time!!!!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    VX don't sell single front springs, they only do them in pairs. The retain cost for standard springs is about £175 a pair - £108 with trade club discount.
    Cambridgeshire
    Or you can do as most do on here and spend about £160 ish on a full set of Eibach springs which are much stronger and improve the handling at the same time without compromising the ride
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Its not just vectras my 54 plate astra Elite had 1 front broken spring.
    Mine had broke just after the protective rubber section.
    Its very bad imo
    Somerset
    Ok, so its not the small fault i had leading to bigger things then. It is mightiliy bad as i've never heard of this before i saw it springing up on this forum. Obviously a gm fault, so why are people paying for replacements?
    Mileage : 55000
    I was talking to the MOT tester last friday about broken springs. He said it is very common for them to break nowadays. Not only on Vauxhall cars. But a lot of other makes too. It seems that it is something that has only come about in recent years, as I can not remember ( nor could he) springs braking on the "older" cars from say 8-10 years ago. I wonder if the quality of the materials is not as good as it could be??.
  1. More broken springs
    By marktaylor in forum General Motoring Chat
    Last Post: 16th March 2012, 22:12
  2. Have I got broken springs?
    By Innes in forum Handling & Braking
    Last Post: 4th March 2011, 20:43
  3. broken springs (mot) vec 2.0 t
    By johnturbo in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2010, 20:14
  4. Broken springs....
    By Mr GTS in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2009, 23:40
  5. Broken springs
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2006, 21:16
