Thread: loss of power
    Regular Member jonnynufc's Avatar
    Belfast
    Default loss of power
    just bought a vectra 2.2 dti sri, there is a light on with a car and spanner on it, seems to be losing power when doing about 60 (only sometimes), any1 any idea whats wrong??
    any help greatly appreciated
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Spanner Light is the engine management light. Could a range of problems.
    May be split hose.
    Gazza4
    Regular Member Robbie69's Avatar
    how long you had it and where did you get it? Take it back if I were you!
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    One of the vacum or boost pipes may be off. Failing that possibly a boost sensor
    Get the codes read
    Belfast
    Smile
    hopefully split pipes then, i bought it private, its sound apart from this, only happens occasionlly, would the air flow metre be anything to do with it??
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    May be the airflow meter. Also if there has been a performance air filter fitted to these engines they sometimes dont like it.
    Gazza4
    Belfast
    dont think there has been, car is completely standard, have to get the codes read, does it have to be done at a vauxhall garage??
    Regular Member philly's Avatar
    wirral
    my last signum was a 2.2dti i had the same problem then after a bit mine started to cut out even at 70 mph on the motorway ended up being the egr vale onece that was replaced everythin was spot on
    EVERYWHERE
    Quote Originally Posted by jonnynufc View Post
    No.Get yourself a code reader off e-bay.Make sure it's compatable with your car.Get one that reads canbus (can) systems to be on the safe side.
    See thread a few below this one.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
