Results 1 to 10 of 16
Thread: Fault codes?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Fault codes?
    I tried something to day that I had heard about.
    Turn ignition to pos 2, hold brake pedal and press and release accelerator pedal at least 4 times in quick succession.
    Then turn ignition off and then back on to pos 2 quickly whilst still holding both brake and acc pedals down.
    The engine warning light then blinked out 2 codes
    1614
    and 1616
    Looking them up they are 'Interactive faults' - any clues anyone?
    Edinburgh
    P1614 Wrong transponder key error (the chip is still in the key?)
    P1614 Wrong transponder immobiliser key B-006
    P1614 immobilizer anti-theft wrong signal B-008
    P1616 CIM (Steering Column module) wrong environment indicator Immobilizer B-006
    I assume the fault codes mean the same between the Astra H and the Vec C?
    Full Member Big Sig's Avatar
    All the fault codes are listed in the trouble shooting section
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Those codes aren't listed, as they are manufacturer specific.
    Just to confirm, there are no warning lights on, and steering and immobiliser work fine...
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Here's the list I found
    P1614
    SBDS Interactive Codes
    P1616
    B1614
    Wiper Rear Mode Select Switch Circuit Short To Ground
    B1616
    Wiper Rear Disable Switch Circuit Open
    I don't know if they are body or powertrain codes, or if they are actually fault codes at all......
    What car is this on? is it running ok with no eml's on?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Sorry to hijack the thread but how do you know what the codes are? What flashes? cheers
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The engine symbol on the dash, the one that is lit before you crank.
    My Vec, but it starts and runs fine with no warning lights, no MIL on, nothing on at all.
    Puzzling
    Edinburgh
    might they just be historical? hence no EML
    A great believer in, if nothing seems broken then don't fix it
    May 2006
    scotland
    Could it be these are defaults with no engine running?
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
vauxhall vectra c p1614 www.vectra-c.com
saab 93 p1614 code
p1614 vectra
