Thread: No Reception
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Default No Reception
    Hi everyone. I've just bought an 02 reg vectra sxi & seem to be suffering from the poor radio reception like several others on here. Usually I get no signal at all until I go up a hill, or bizarrely across a bridge local to me!
    The front of the radio looks like its been taken out before so I was just wondering how to take out the radio (its a cdr 2005) so i can check the aerial is connected properly. I've taken the 4 little screws in the corners out but didn't want to force the front off.
    Also could you tell me how the aerial is attached to the roof? Does it clip in or is it secured from underneath?
    Any advice would be greatly appreciated.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    You'll need radio pins to take out the radio. You can get them from halfords ot online. The aerial is held by a bolt from underneath
    once the little allen bolts are out, you can buy pins as said, or in the past i have used screws or nails or thin screwdrivers.....yes i am cheap
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    cheers for the quick response fella!
    Surrey
    Sounds like it has had an aftermarket headunit and hasn't put it back correctly.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Cheers for all the comments guys. I believe the fault is a poor connection between the radio and the aerial socket. I'm going to take the socket off the back of the radio & solder it cos it does feel a bit loose.
    Is there any way i can get at the back of the radio while its installed to check its not just a case of the radio & socket not quite fitting as they should?
  1. Radio reception
    By Graeme in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2010, 23:16
  2. FM reception
    By 137mph in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2009, 02:56
  3. AM reception
    By jaxouk in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2008, 19:22
  4. Bad Reception!!!!!
    By m_r_shaw in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2008, 16:32
  5. tom tom 300 GO reception.....
    By Harry in forum Electrical & ICE (including SatNav)
    Last Post: 3rd September 2005, 00:00
cdr 2005 no fm reception
