Results 1 to 10 of 16
Thread: Heater Fans Died
    Newport
    Default Heater Fans Died
    Just driving on my way home with the heating on and all of a sudden they fans just stopped and wont work at all.
    Ive got 04 plate elegance estate.
    Anyone got any suggestions?
    Thanks in advance.
    check the fuse? Also remove the pollen filter to check the fan isn't stuck or siezed
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    try this link i fixed mine using it
    http://www.vectra-c.com/forum/showth...hlight=heaters
    Regular Member Lump's Avatar
    coventry
    whos Heater Fans
    Quote Originally Posted by Lump View Post
    whos Heater Fans
    lol but
    and yes, try the fuses.
    Newport
    thanks for the info guys ive now checked over the fuses all look fine, as long as there is only supposed to be 3 as thats all i found related to heaters. Andymcniven i looked at your thread and checked out the blue relay looks fine the relay closes 1-3 then opens back up on number 4.
    fan isnt stuck and pollen filter side is clear.
    Any more suggestions of what it could be guys?
    loose connections on back of heater controls?
    Newport
    would that be relevant if the lights still show for the windscreen demisting button and that doesn't turn the fans on either.
    Sorry if im sounding a bit thick aint the best with fixing cars
    not too sure mate, however i did have my heater controls puller out earlier when i was messing with my phone kit and there were definatly 2 conectors.
    Newport
    think i may have solved the problem, upon closer inspection there has been water coming in through the fan and resistor pack is wet so i think after reading some of the write ups on here i might change that first
  1. heater fans not blowing
    By Jaspa in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2011, 16:37
  2. heater fans not working?
    Last Post: 2nd December 2011, 23:06
  3. Which relay controls heater fans
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2009, 19:00
  4. Car Died!!
    By Silver V in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2007, 10:31
