Results 1 to 10 of 17
Thread: CIM Warning
    Full Member
    Bristol
    Default CIM Warning
    Advice for all vauxhall owners with Can bus. If you need a sterring wheel CIM, only buy secondhand if the CIM has been blanked off the system with Tech 2 before removing from donor car using the paas card issued with the car. And it will have to be programed into your car with tech 2 to work correctly. If you buy a sim from ebay or another source that has not been blanked before removal it will not work unless you have all the cam bus modules associated with the CIM and there is a lot.. There is no way round it at all.
    Full Member Big Sig's Avatar
    Find out the hard way did you?
    Northampton, UK
    Thats pretty much the way it all works on the canbus cars TBH mate... There's not much that can be swapped electrical wise without being unpaired
    Full Member
    Bristol
    Found out the easy way. Done some research before taking the wrong steps . Found a breaker in romfors that has tech 2 and blanks them before he removes them.
    Northampton, UK
    Quote Originally Posted by sb1uk View Post
    Now that is rare, that a breaker has the right kit and bothers to do it!
    Full Member
    Bristol
    There is a breaker the repairs cars in bristol with Tech 2. it is rare. That one in romford will sell you a Cim and program it in .
    Admin plasma's Avatar
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    It can be done! But you need a friendly Vx dealer, they can pull the VIN number off the unit and then get the car pass for said VIN number which will then have the code on it. Then its an easy matter of recoding it. Will cost an extra £20 to do it.
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by plasma View Post
    I know a lot more can be done then the dealers like to let on
    esp with so called coded items !
    Full Member
    Bristol
    Well i am not willing to buy one and take a chance. Even a stealer mech said today they have cars booked in with s/h cim and the can't be reprogramed unless blanked before removal from donor car. So buy new £139 or scondhand blank for £75.
    Full Member
    Bristol
    Quote Originally Posted by 900ss View Post
    Mine has the esp on all the time.
  1. air bag warning
    By shaun 37 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th June 2014, 10:31
  2. Warning to all men!
    By Jim Bob in forum Comedy & Humour
    Last Post: 14th February 2011, 22:58
  3. ******warning*****
    By peter-gsi in forum General Chat
    Last Post: 15th December 2010, 18:23
  4. Warning...................
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 18:20
  5. Oil Warning - How far can I go?
    By aaruck in forum Engine & Drivetrain
    Last Post: 30th October 2008, 08:55
