Results 1 to 10 of 30
Thread: I want to fit Cruise Control to my Vec-B
    Birmingham
    Default I want to fit Cruise Control to my Vec-B
    Guy's,
    I want to fit cruise control to my Vectra-B.
    I havent got the kit yet and to be honest, I dont really know exactly what i would need, ideally it would need to be a second hand setup.
    First off, is it possible for a 2.2 SRI DTI to have the Cruise Control??
    If so, whats involved and how hard is it install and setup?
    Also, what do I need and any idea's where I can get the kit from?
    I have checked other forums and a lot of people have the V6 stuff, but doubt that would fit mine as different gearbox.
    So far, all I know is that it usually consists of:
    - Stalk;
    - Cable;
    - Gearbox Module.
    What else?
    Also has anyone actually done this on their own current or ex-Vec-B's?
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I fitted cruise to my old Vec B 2.0 DTi on a 51 plate.
    All it needed was the indicator stalk with the buttons on the end.
    If you remove the top steering column cowl, there should be a small 4 pin plug. The extra wire from the stalk just plugged into this.
    10 minutes and not a lot of cash.
    All the programming for CC was already in the ECM.
    Birmingham
    So am I correct in thinking that the module, etc/cable, is all already there??
    You have got me excited now....I know, I know, it doesnt take much does it?
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Craig1985's Avatar
    harwich essex
    i had to fit the clutch brake sensor too,
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No module, it's in the ECM as the engine is electronic.
    Nothing more to add to get it to work on mine, just the stalk. Clutch switch already there on mine
    eg http://cgi.ebay.co.uk/VAUXHALL-CRUIS...3%3A1|294%3A50
    Birmingham
    ..... now we are getting into the nitty gritty....worth tyring the stalk alone first?
    Bye bye Vec B
    - Hello Siggy!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by Vaux-Man-G View Post
    Definately, as yours will have the fly by wire throttle, so that should be all thats needed (with maybe a splatter of Tech2).
    Birmingham
    On the Vec-B, are the CC buttons on the indicator stalk or wiper?
    Bye bye Vec B
    - Hello Siggy!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    No tec needed on mine, either.
    Indicator, same as C
    Just fitted the cruise stalk and off it went.
    You could always try before you buy anything.
    The 4 pin plug I mentioned, one has a main +12V feed, and the other pins are pulsed from this feed to do either Speed +, speed - or cancel.
    I actually drove down a quiet road with wires coming from the plug and a mate just touched the power wire to the others to see if it all worked. It did, so I bought a stalk.
    Remember that there will not be any dash light lit up, like the Vec C
    Birmingham
    I might just buy a stalk and see how it goes....if not its the start of the project?
    Where can I get one from?
    Bye bye Vec B
    - Hello Siggy!
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
