Results 1 to 3 of 3
Thread: 3.2 V6 injecter flow rate?
    Orpington
    Default 3.2 V6 injecter flow rate?
    Does anyone have the info on the flow rate of the injectors.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    What flow rate are you after? Max, average, min, and how accurate do you need it and for what purpose?
    Orpington
    Well i have a 3.2 V6 im running with 2.5 auxcillarys which have been opened up for the same air flow etc as the engine is in a Calibra.
    The injectors i have are from the 2.5 as i have to use the rail from the 2.5 because of the loom and connections.
    The standard injectors run at 190cc but i have an upgraded 3.0 ecu which has been superchipped so was wanting to find out the 3.2 flow rate and the 3.0 flow rate so i can get a good flow rate.
  1. Yaw rate sensor
    By lee632 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 23:24
  2. How Do You Rate These ?
    By Tam80 in forum Handling & Braking
    Last Post: 21st January 2011, 20:56
  3. vectra 2.2 dti injecter seals
    By waynezz in forum Engine & Drivetrain
    Last Post: 27th February 2010, 23:05
  4. Full take up rate?
    By Ste in forum General Chat
    Last Post: 6th December 2009, 20:09
  5. New Tax rate
    By MLC in forum General Chat
    Last Post: 24th March 2006, 15:58
