Thread: 1.9cdti traction control switch
    wolverhampton
    Unhappy 1.9cdti traction control switch
    hello peeps i know people have seen questions on this before but i need help. I found a thread on fitting a tc switch on a vectra 1.9cdti. its says if you remove the blank cap and there is a blue plug, buy the switch fit it and your away. not in my case. got the blue plug, fitted switch but no go. ive heard that it can be enabled on tech 2 so i went to vx and they had ago. No clue at all. Can anyone help.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    TC may NOT work even if the blue plug is present, and if it doesn't I seem to remember from posts on here that it was a wiring issue (missing wiring and/or connections?). As far as I know it's got nothing at all to do with Tech 2.
    Regular Member MattW's Avatar
    Sheffield
    Mine had the blue plug, but didn't enable me to turn off TC.
    Full Member Big Sig's Avatar
    let the search button be your friend!
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    tech2 has nothing to do with it: the cable to the ABS control unit (pin 3) will be missing; this pin must be grounded to switch TC off
    some guys managed to do this; have a search on the forum: thousands of posts about it
    Found the one needed
    wolverhampton
    Default i have everythinh but still no go. switch and wiring
    looked at the link which explained about the missing wiring and adding it to pin three but ive looked at my car and it has the wiring going to pin three. looked at the back of the switch to and the wiring from the blue plug goes into the loom at the back of the dash. can anyone help cheers
  1. Traction Control Switch
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2010, 22:04
  2. Traction Control switch
    By chrisgettings in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2007, 22:42
vectra c traction control missing wiring
vectra c cdti 150bhp traction control button
adding traction control to vectra c
How to add traction control to vectra c
How to fit traction control on vectra c 1.9
vectra c tc off
putting traction control on vectra c
what is tc switch for opel vectra
vectra c disable traction control for dyno
how to test vectra traction control
traction control vectra c
vectra c cdti the traction control fuse
vectra c tc button
