Thread: problem with engine
    May 2008
    Llanelli
    Default problem with engine
    Car went back into garage today and they told me that there is a problem on the car causing reduced power from car recognising a fualt. Problem is a Turbo overboosting that is taking place when accelerating but they dont know what is causing it. He mentioned that there were 2 ways to get to the bottom of the cause:
    1) using a Cambus system??? which they dont have which can test solenoids/sensors on computer system - only available from main dealers (expensive)
    2) stripping engine down further to check for mechanical faults from faulty 'air valves'
    Any experience or ideas on what I should do next?
    darlo
    scrap yard thats were mines going if it gives me any more chew
    main dealer for a tech 2 session.
    Regular Member mattolly86's Avatar
    oxfordshire
    yep unfortunatly you cant beat a good tech 2
  1. engine problem
    By johnnyhg in forum Engine & Drivetrain
    Last Post: 2nd October 2009, 19:30
  2. Vec C 1.9CDTi 150 engine problem
    By ROCKATANSKY in forum Diesel Engine related
    Last Post: 1st February 2009, 14:19
  3. Cdti 150 Engine Problem
    By scad2k in forum Vectra C / Signum Troubleshooting
    Last Post: 25th August 2008, 21:31
  4. Problem when turning engine off!
    By user999998 in forum Engine & Drivetrain
    Last Post: 17th June 2008, 01:25
  5. 2.2 Engine problem
    By hamish178 in forum Engine & Drivetrain
    Last Post: 8th November 2007, 00:40
