Thread: vectra 1.9cdti 150 obd scanner which one
    london
    Default vectra 1.9cdti 150 obd scanner which one
    hi there
    could you please point me in the right direction on which scanner light ressetting scanner i need for my car
    i have a 04 vectra c 1.9cdti and im getting missfire
    i have cleaned egr but not the solonaid as it semms to move freely
    was thinking of doing the injector 3 wiring mod but would like to buy a scanner first too see if there are any faults first
    thanks
    EVERYWHERE
    Quote Originally Posted by in7ox View Post
    hi there
    thanks
    One of these will do the job.
    http://cgi.ebay.co.uk/CAR-DIAGNOSTIC...3A1%7C294%3A50
    Just make sure it reads canbus (that U480 one does) and it should be fine.I've just got the same one for my V6 diesel and it works fine.
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Clean the solenoid side. Mine seemed to move ok but when taken apart and cleaned it resolved by problem. Like you I also tried the 3rd Injector wiring mod but this didnt help. I done the EGR valve side first but this didnt help. I really recomend doing the EGR valve solenoid side next, it's not as hard as it looks and if it's broken you cant break it any more now can you? You will need a vice and a small long centre punch to get it out because it is in there quite hard.
    london
    thanks for the advice
    will do both
    thanks
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. vectra 1.9cdti and astra 1.9cdti clutch
    By abz123 in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2012, 21:01
  3. Ecu scanner
    By robengland9 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2011, 19:34
  4. OBD II Scanner +/- CAN Protocol
    By rheumatoid in forum Engine & Drivetrain
    Last Post: 20th August 2009, 17:23
  5. Anyone use a scanner ?
    By rob 2.2dti in forum General Chat
    Last Post: 11th April 2009, 17:53
