Results 1 to 10 of 11
Thread: foaming
    Regular Member WKD-mcc's Avatar
    glenrothes
    Default foaming
    i;ve read through a guide of how to get the perfect finish on your car.well it says you spray on the snow foam,let it dwell,then spray up with the pressure washer,then again and spray down.well i understand the spray up and spray down,but for doing the sprayin would i need to switch over the lance back to the standard one for the wash it down,or can i wash it down with the foam lance,obviously with out the foam bottle on though.or do you jsut let it dwell and run off,then get straight on with the mitt and buckets?.what do you regular snow foamers normally do?
    Newcastle under Lyme
    The lance is a whole unit and you disconnect that and refit the original pressure piece
    Chester
    Reconnect the standard lance to remove the foam. I then wash the car as normal with a wash mitt and two buckets. The foam (at least the stuff I'm using) is just there to loosen the dirt.
    Quote Originally Posted by Stevel View Post
    Might I add that it does it very well with no contact. ps dont forget the arches
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Or if you want to be really posh Autobrite sell a lance that does both, foam and high pressure, like one of those double necked guitars Kiss used to have LOL
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i remove the foam lance and get the power lance on it
    He never told me about that when I went down
    glenrothes
    hmm al pass and settle for the changin it over lol,am not a posh totty for the double act a think .cheers lads,just checkin to make sure,thought i'd have to do that but its all good to double check and keep myself right
    glenrothes
    would you need any fittings for a hose extension,been lookin at them on autobrite but not sure what im lookin for,jsut out fo curiosity not looking to buy just now,as said on another thread am havin to move my pressure washer about everytime i go to the other side due to where i have to wash the car and its gettin pretty annoyin havin to do this all the tiiiiiiiiiiiiime looked at the hoses,the 8 meter 210 bar rubber hose,they have connections on them already so would they just fit straight on.or just save the hassle and ask king of autobrite mark himself
    Ask Mark. My Karcher came in 3 pieces - Trigger, Hose and Main Unit but pretty sure the hose would need the appropriate adaptors to fit the unit and trigger
  1. Snow foaming the engine bay?
    By peelmeister in forum Detailing and Car Care Discussion
    Last Post: 14th April 2012, 10:17
  2. Loosing coolant & foaming
    By si_hoss in forum Engine & Drivetrain
    Last Post: 27th January 2012, 14:12
  3. Rinse before snow foaming?????
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2010, 17:44
  4. Absolutely foaming
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2007, 12:29
