Thread: tyre sizes
    Regular Member chrissri82's Avatar
    Apr 2009
    airdrie
    Default tyre sizes
    hi guys,
    gonna be changing from 215/50 17 to 225/45 17.
    can someone tell me if i need to change all 4 or can i do 2 at a time
    and whats currently on the market thats recommended.
    thanks in advance
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    You certianly can do 2 at a time mate as long as their on the same axle..ie rears first.
    do the rears first as they are wider..wont upset the handling.
    Apr 2009
    airdrie
    thanks mate
    11 Post(s)
    Quote Originally Posted by Dose View Post
    My 225/45/17's are on the front. The 215/50/17's are still on the rear.
    If anything the handling has improved because I got shot of the NCT5's that were on the front. You're talking a marginal size increase, at the end of the day it won't matter which end of the car you fit the wider tyres to.
    As for a recommended tyre, try Uniroyal Rainsport2's.
    Apr 2009
    airdrie
    thanks big dave
    Regular Member powelly1592's Avatar
    May 2008
    Seaton Delaval, Tyne & Wear
    Changed the fronts on my siggy last week, Hankook Ventus V12 evo's from Camskill for £62 each. Spot on! Really good tyre so far, not tried them in the wet yet
    Ingleby Barwick
    My 215/50/17s are getting a bit low and after reading all the threads on this am thinking of replacing them with 225/45/17s instead. Folk had said in other posts that 225/45/17s fit on the rims fine but I'm struggling to understand how this can be the case.
    As I understand it the first figure is the width of the tyre in mm so the 225s are 10mm wider than the 215s. If you don't change the wheels then how can a tyre 10mm wider still fit? Do the rims have a very wide tollerance for what tyres can fit on them?
    Tyres are made of rubber which has quite a bit of play in it mate. The rim is a standadrd size, it's just the tyre that expands to fill in the width of the rim. If you look in your handbook, you'll find both sizes mentioned, meaning you can use either.
    Someone on here has fitted 255 width tyres...
    11 Post(s)
    Quote Originally Posted by klesniks View Post
    Here's my Vectra with 225/45/17 fitted at the front, and 215/50/17 on the rear:-
    Front:-http://img155.imageshack.us/ifs/9496...09528front.jpg
    Rear:- http://img42.imageshack.us/my.php?im...009529rear.jpg
    Honestly mate, 225/45/17 will fit your rims.
  1. Which tyre sizes
    Last Post: 5th October 2012, 00:42
  2. Tyre Sizes
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2011, 19:29
  3. tyre sizes
    By mrpatterson2008 in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2010, 17:50
  4. Tyre sizes
    By MLC in forum General Chat
    Last Post: 15th January 2009, 23:50
  5. Tyre Sizes
    By Pendo in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2006, 23:02
