Results 1 to 10 of 18
Thread: WARNING To Owners with Tuning Box's
    Leicester
    Default WARNING To Owners with Tuning Box's
    As you know, my car is in the process of having the DMF changed, and I had an interesting chat today.
    Vauxhall have become aware that Vectra/Signum DMF problems can be highlighted and made worse by the use of the tuning box. Dealers can check what max pressure the fuel pump has been running at and can compare it to the max pressure it should be running at.
    If there are descrepancies, a warranty claim can and will be turned down. Vauxhall are checking for this now on cars they suspect have been messed about with.
    The reason so I am told is that the tuning box does not limit the torque in first and second gear and puts major stress on the DMF.
    You have been warned!
    Regular Member philly's Avatar
    wirral
    thank god i took mine out lol
    Jan 2006
    Dalriada
    Good head's up to the oil burner's Matt
    May 2006
    scotland
    Ok, well here is a thought. Vx must read the fuel pressure data from a memory bank somewhere. I wonder if this data will be wiped if you disconnect the battery overnight????? If so, therein lies the answer to you boxed people. Just a thought.
    Regular Member MattW's Avatar
    Sheffield
    Quote Originally Posted by Maverick View Post
    But driving in a sensible manner while in first and second shouldn't cause an issue? Who would be stupid enough to boot their car in first and second gear all the time anyway, and putting the max torque through the drivetrain?
    Doing that would kill the clutch eventually on most cars.
    WGAF#5
    posted by me 21st april
    http://www.vectra-c.com/forum/showthread.php?t=79091
    just recieved a very intersting email from Peugeot regarding power kits (diesel tuning boxes) being fitted to their vehicles -
    We have been alerted in Germany by several cases of melted pistons on the 2.2 litre diesel engine.
    The technical inspections carried out on two of these incidents have concluded that the most likely cause was the fitting of a power
    kit. One of the units analysed misled the ECU input parameters resulting in an injection rail pressure several hundred bars higher
    than it should have been."
    they are now advising all dealers to check all vehicles with running faults
    and report any case of suspected or fitted kits to contact them immediatley as warranties would be invalidated - just thought i would make you aware as most manufacturers follow suit very quickly regarding such matters
    for your information
    Cambridgeshire
    I am guessing that Remaps don't have the same effect as they are tuned specifically to the car and most remaps put a limit on the torque (300lbft)(especially for the 150's) as the DMF's can't handle that much torque.
    Am I right in saying this?
    Birmingham
    Blimey, that is good to know for the future! Thanks for that!
    Bye bye Vec B
    - Hello Siggy!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I would say that some stored data isn't volatile and therefore removing the battery will not delete it.
    As I said previously, why should VX pick up any failure costs for those people who fit deevices that take the engine out of it's normal, validated operating areas? Surely it should be at own risk?
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    Quote Originally Posted by Ste View Post
    Have to agree, once you start messing with a car it isnt how it left VX so really they should have no responsibility as its not normal wear and tear
  1. Tdi tuning box's - any good ??
    By Mark Curran in forum Engine & Drivetrain
    Last Post: 13th July 2011, 17:51
  2. Diesel tuning box's 1.9 cdti 120
    By tom8y in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2009, 22:11
  3. Warning for estate owners...
    By JuzzyD in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 20:56
  4. DTUK tuning box's
    By vex in forum Diesel Engine related
    Last Post: 29th May 2008, 12:29
  5. Tuning box's ???
    By shan in forum Vectra C / Signum Car Chat
    Last Post: 9th July 2007, 22:23
