Results 1 to 10 of 20
Thread: Air Con / Warranty Qn
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    Default Air Con / Warranty Qn
    booked in the stealers this week (under warranty) as the air con does not work, cannot tell any difference through the vents when its switched on...apart from a sound (sounds like someone is blowing though a straw) anyway my question is even if it needs re-gassing is it still under cover ? my argument being if its a leak-pipe-seal problem, or even compressor it should be covered ? I will make it clear before I hand over the keys that I want informing if its chargable, as imo (tell me if i am wrong here) air con should never need service unless it fails/leaks.
    also wanted a rattle sorting on my door, no chance they said as its only covered for the 1st 12 months, & my gear knob came off in my hand again today quite fancy a VXR one....
    Leicester
    You will need a re-gas and the is NOT covered under warranty. No point in arguing with them over it as the gas is classed as a consumable.
    My sister in law had a similar issue with her Corsa SXi+, the air con was not right and she had to pay for a re-gas at 2 years old.
    Regarding the rattle, your dealer is right, rattles and trim faults are only covered for the forst 12 months.
    I had a faulty gearknob selector on my Astra and the whole shift mechanism needed to be replaced, I got a VXR one and paid the difference of £6.00!
    Regular Member kns's Avatar
    Northampton
    I have just had to have the air con re-gassed after 3yrs you may of sustained stone damage on your condenser,this possibly causing a slow leak which also will not be covered on your warranty.
    Regular Member Avenged's Avatar
    Liverpool
    mine had gone on my 07 vec!
    went to kwikfit..£45
    top job!!
    Glasgow
    You will always pay for an air-con recharge simply because they are recharging it with gas and they do eventually need done, a good way of prolonging the life of the air-con system is to run it for a period of time even in the winter to keep everything flowing nicely.
    Apr 2008
    Staffordshire
    thanks for the replies, its going in tomorrow!
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    got mine done yesterday at vxl.... new condensor fitted under warranty and got my 99 quid back for the regas well pleased
    Regular Member Fruit'n'nut's Avatar
    Re-gas on mine was covered under warranty, earlier this year.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I am about to book my signum into the dealer ref. aircon aswell! It stinks like sweaty socks!!! lol.. best be covered under warranty as mine runs out in june
    Northampton
    Quote Originally Posted by luke4487 View Post
    Have you checked the pollen Filter?
  1. Do I get a warranty??
    By scotty84 in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2011, 13:00
  2. Warranty Direct or AA Warranty
    Last Post: 20th March 2010, 12:31
  3. Warranty
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2009, 22:04
  4. warranty
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2009, 21:13
  5. Stealerships...warranty or no warranty, that is the question!
    By David_SRi_2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 15:48
