Results 1 to 10 of 13
Thread: Ign Logic
    Edinburgh
    Default Ign Logic
    was playing about with my Vectra's computer today and noticed in the system settings there is "Ign Logic" which is on but can be turned off. Anyone know what this is and what difference having it on or off makes?
    Thanks.
    Regular Member gaz4d's Avatar
    Glasgow
    Is it not something to do with the CD/Radio system, and it staying on/off when the ignition is on/off ?
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    As above, it means when you turn on or off your ign,the stereo does the same
    Regular Member andymcniven's Avatar
    newcastle upon tyne
    Regular Member barkzz's Avatar
    Quote Originally Posted by fenderguitar View Post
    Its the first option taht should be set to off!
    Nothing worse than the damn radio coming back on when you dont want it to.
    Irnoically if you have had your car in, and its been on the "laptop", its always comes back with it turned back on!
    Regular Member marky2027's Avatar
    Northumberland
    This Ign logic gets right on my wick!! hate the radio coming on with the ignition! When set to off though and you park up somewhere and turn the engine off the radio stays on!!! What's all that about??
    Edinburgh
    oh good, I'll be turning it off then cause it annoys me too. Thought it might be something to do with the engine so didn't want to change it until I knew what it did. Cheers lads.
    Northumberland
    I though it would be a good idea until I parked up and the radio stayed on. I would say that's even more annoying TBH!!
    One thing I did try is leaving ign logic ON and turning the switch on volume to the min level. The radio comes on with the ignition but you can barely hear it. Simples!!
    Edinburgh
    Quote Originally Posted by marky2027 View Post
    I finally remembered to have a play with this setting and I have to agree. it's annoying switched on but even more annoying switches off when you go to get out the car and realise the radio is still on. grrrrr. So it's staying on.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Strictly speaking, Ignition logic setting simply determines that the radio/CD unit retains the same status as when the engine was last switched off. So if the unit was off when you last stopped the engine and removed the key, it will not come on when you start the ignition, if it was on then it will come on when you start the ignition. Changing the ignition logic to 'off' means that the CD/radio will not come on when you start the ignition, irrespective of its status when you last switched the engine off and removed the key.
  1. Women and logic.....
    By TonyP2020 in forum The 'Off Topic' room
    Last Post: 28th January 2013, 11:28
  2. Cant see the logic in buying second hand ?
    By wolvesdaz in forum Vectra C / Signum Car Chat
    Last Post: 15th May 2012, 13:34
  3. DAS-6 Machine polisher,Pads,Dodo,Megs,Hex logic,Sonus
    By bigmac in forum General items for sale
    Last Post: 23rd April 2011, 21:38
  4. Irish Logic
    By Tadpole in forum Comedy & Humour
    Last Post: 9th February 2009, 22:49
ign logic
ign.logic
ing logic astra h
ignition logic corsa c what does that mean
vauxhaul astra ign logic
ign logic off opel
Vauxhall ign. Logic
corsa ignition logic
astra h ignition logic
Vectra c ign.logic
ingn. logic opel
ign. logic astra
astra h ign logic
what is ign locgic on off
opel ign logic on
what does ignition logic mean opel astra
what is ign logic on astra
ign logic opel
ign logic opel vivaro
what does ign logic mean
ign logic in a vectra
what is Ign logic
ign logic on
Ign.logic on
