Results 1 to 10 of 21
Thread: HID Which Kit and where
    Jun 2007
    Mold
    Default HID Which Kit and where
    After a set of HID's for my 2006 Vec XP
    Thinking about an 8000 or 10000k set, not sure which.
    Which bulbs have to be changed all in all.
    Heard its the H7's I need?
    Which other bulbs require changing?
    Is it worth doing the fog light's as well?
    Any help asap is useful as want them ordered ideally today so I can fit them before the weekend.
    Been looking Ebay but not sure who to go with, or what bulbs etc required
    Full Member
    Bristol
    4k to 6k is the best the 8k 10k 12k just show more blue and less distance. 4 is the industry standard fitted to all cars. I have 6k with clips to suit your car fro £50 plus postage. Same as I have just fitted.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Quote Originally Posted by sb1uk View Post
    Best..???
    4.5k gives the most light, anything above turns blue (until 12K which are more purple) and gives off less light (but still loads more than Halogen) - the best (I would say) is the one which YOU like the look of most
    Jun 2007
    Mold
    i am thinking 8k at the moment
    just not sure which bulbs are required
    obviously i need the H7 but are there others in the head light worth changing?
    also does anyone know about the fogs and how easily they can be done?
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by jamesgsi1983 View Post
    You are best to change to sidelights too (501 push in types) purely as the std ones will look very yellow next to HiDs. These are the only ones you "need" to change.
    Any others is upto you.... fogs have been done before, not sure on the type though, I think they are H3's - not 100% though.
    Jun 2007
    Mold
    anyone know where I can get a decent set for cheap on ebay with a trusted seller with quick delivery?
    Full Member
    Bristol
    No On ebay hid kits are between £60 -£100 mine were £69 AND SOMETIMES DO NOT COME WITH CLIPS TO FIT THE NEW H7 BULD FITTING ON VECTRA C AND ASTRA H
    Lancashire
    Trim : XP NAV
    Does yours have cancellors too..??
    Never seen the need for the clips though, as with a simple snip of some pliers, the OE ones can be modified for a nice tight fit (with the HiD wires fed through).
    Jun 2007
    Mold
    can anyone reccomend a seller on there where they know they come with the H7 Vectra fitting bracket
    looking to hopefully order some this evening
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I have 6k and there blue enough for me
