Thread: Modding an Irmscher Grille
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default Modding an Irmscher Grille
    I have noticed that my Facelift Irmscher Grille has the top row of slats blocked off at the back which is also where the air intake is for the air filter. I have thought if this should be open or not as there is no direct flow of air into the inlet but instead the air is coming underneath the intake.
    When you buy one of the induction kits that have a cold feed pipe it sits open with a direct flow of air hitting it so I thought that maybe it might be a good modd to try.
    Comments please chaps
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i cut out the top blocked piece on the original vx sri grill and all it did was pull the bloomin noise deadening on the underside of the bonnet down onto the engine cover.....
    Midlands Mod Shop - NFFC.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The flap is there so diesels don't get hydraulic lock. You can take it off but beware large puddles.
    May 2007
    WINSFORD
    I just thought that if the itake had a direct air feed it might bump the performance up a little bit but if its risky I will leave alone.
    I cant compare it against an OE grille has I have sold it
    Vehicle : SRi
    Mileage : 137000
    Put it this way, nutron strapped a leaf blower to the intake of his CDTI and took it on a rolling road, it gave no performance increase what so ever. So removing a flap to let more air in isn't going to do anything.
    May 2007
    WINSFORD
    I will leave alone then, it was just a thought.
  1. Replies: 3
    Last Post: 3rd May 2011, 17:52
  2. Prefacelift Irmscher Style Grille with Irmscher Badge...
    By Dan_BlackSRi in forum Parts for sale
    Last Post: 26th November 2009, 10:30
  3. Irmscher Grille
    By jamesr in forum Parts for sale
    Last Post: 28th April 2008, 21:30
  4. Irmscher Grille
    By S888 SRB in forum Parts for sale
    Last Post: 4th October 2007, 06:47
