Thread: 2.2 Petrol Misfire/Stalling Help Needed
    cheshire
    confused 2.2 Petrol Misfire/Stalling Help Needed
    Hi
    I have a 2.2 petrol vectra c and each time you start it up it'll stall, it tries to fight this but in the end it stalls, my mate reckons it is misfiring. Once started and going it runs fine this just happens on startup. I put on a diagnostic tester and there are no fault codes being stalled, i've changed spark plugs and cleaned EGR valve but the problem is still persisting!!! Can anybody help me please?
    John
    Regular Member davree's Avatar
    Warton
    Vehicle : Insignia
    Engine : 2.0 CDTI (160)
    Year : 2010
    Mileage : 26000
    You could try changing the fuel filter for a start (they are quite cheap). Also try cleaning the throttle body!!
    You could have a faulty/clogged injector, you could try putting some redex or similar in the fuel which contains injector cleaner to try and clean them up.
    HTH
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Coil pack or o2 sensor. Mine misfires a little on start up, but as soon as its under load it goes. Mine's due to a sticky hydraulic lifter. Does it make any noises at all?
    cheshire
    ok will try fuel filter,have had a little go at cleaning the throttle body but i'll take it off to clean it next, will also purchase some redex, it makes abit of a knocking noise when its trying to start but that about it, can i just enquire where is the o2 sensor? not sure what one is or does?
    Vehicle : SRi
    Mileage : 137000
    O2 sensor is the lambda sensor mate, one in front of the Cat and one after.
    cheshire
    Thumbs down worse
    Hi have used some redex and have changed fuel filter, problem seems to have got worse, its constantly searching for revs when its started up also i now have a MIL light coming on. Will clean the throttle body and EGR Valve once more has anyone got anymore ideas?
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    i would change the coil pack mates vectra b 2.2 had similar problems
  1. Low rev misfire. 2.2 petrol
    By jrh1 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th September 2012, 16:38
  2. 1.8 petrol stalling
    By baz_cdti_sri_150 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 21:01
  3. cdti 150 slight misfire! help needed
    By craigz9876 in forum Engine & Drivetrain
    Last Post: 30th October 2009, 11:11
  4. 3.2 V6 Petrol GSi Misfire Under Load
    By marcdale in forum Engine & Drivetrain
    Last Post: 31st May 2009, 21:22
  5. signum 2.2 petrol misfire
    By scotty6w in forum Engine & Drivetrain
    Last Post: 14th July 2007, 14:03
