Thread: Battery in key died, now it needs reprogrammed??
    Regular Member kgsric's Avatar
    Northants
    Default Battery in key died, now it needs reprogrammed??
    on thursady night the battery in my key died & an alarm came up on the dash,
    Mrs took it to vx today to get a new battery but locks etc work inconsistantly, she was told it would need reprogrammed for £25 due to the amount of time it was dead,
    Surely nearly 5 days without a full batt shouldnt need reprogrammed?
    What can i do?
    Full Member
    Bristol
    I have never heard of that. put battery in put key in ignition press buttons
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    open the doors with the key so the alarm goes off. jump in quick and turn on the ignition, just to the second click. pres the door open button on the key fob and the doors should lock then re-open pretty much straight away. job done all set again! HTH, mick.
    11 Post(s)
    Depends on the year of the car. There are two different procedures depending on which handbook you look in. One of them is mentioned above. The other below:-
    The other way is to unlock door with key in lock. Inserting the key into the lock synchronises the remote control.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    cheers dave. i didnt realise there was other procedures.
  1. battery died now no centre screen
    Last Post: 18th February 2013, 23:15
  2. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. CDR2005 radio not working after battery died!
    By dangriffin87 in forum Electrical & ICE (including SatNav)
    Last Post: 5th June 2011, 20:47
  5. injectors reprogrammed = more power?
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 13:42
vectra c key fob battery dead will it need reprogrammed
54 vectra c key fob battery
