Results 1 to 10 of 27
Thread: Clicking noise from dashboard on startup
    Regular Member deanos's Avatar
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Default Clicking noise from dashboard on startup
    When i turn on the ignition there is a clicking noise for about 5 seconds from behind the dashboard, its either behing the stereo or glovebox.
    I think its to do with the re-circulation , because if i turn it on then off again it makes the same noise, but only when turning off it makes the noise
    Any ideads on a fix or what it could be ?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks for that,so it sounds like "heater flap recirculation flap solenoid motor"
    Any idea where that part is on my car and easy to fix ?
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Anyone know where the solenoid is located ?
    Surrey
    Behind the glovebox.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    thanks
    Winteringham
    Changed mine the other month got quoted £85 from dealer went to local scrap yard and it cost me £10 fitting is gitt very tight space took me about 20 min to remove from car in scrap yard just pulled the hole AC unit out and 2 hrs to fit on my car took my time but once fitted all working OK
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Thanks, Was that £85 for the part or part & fitting ?
    I presume you need to take all the glove box out ? I wounder is WD40 would solve it ?
    Surrey
    Yes take ALL of the glovebox out 5 torx T20 bolts 2 mins max for starters. WD40 er no.
    UK
    Vehicle : Insignia
    Engine : 2.0
    Year : 2011
    Ok will have a look behind there later to see what it looks like
  1. Weird rubbing noise on startup
    By Jamesie82 in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 20:50
  2. Scraping noise on cold startup.
    By erni3wi5e in forum Engine & Drivetrain
    Last Post: 18th March 2012, 14:20
  3. knocking noise on startup
    By simon7257 in forum Engine & Drivetrain
    Last Post: 24th February 2010, 17:17
  4. startup grrr noise
    By andreitone in forum Engine & Drivetrain
    Last Post: 21st November 2009, 16:23
  5. Groaning Noise On Startup
    By VauxVeteran in forum General Chat
    Last Post: 24th December 2006, 04:11
vectra c clicking noise behind dash
vectra c knocking noise from heater
vectra c clicking noise from dash
vauxhall vectra relay ticking
vectra clicking behind dash
vectra c heater clicking
vauxhall zafira clicking noise
Vauxhall zafira 1.6 comfort year 2000 clicking from under dash when running
vectra clicking noise
vectra clicking when ignition turned on
vectra c noise dash
vauxhall vectra 2004 clicking in glove box
ticking noise inside dash of vectra
vectra c heater makes clicking noise
vauxhall vectra c clicking from dashboard
vauxhall vectra heater fan clicks when first starts
vauxhall vectra radio making clicking noise
vectra c recirc flaps click
vauxhall vectra knocking noise dashboard
vauxhall vectra clicking noise
why is there a clicking sound coming from the glovebox of vauxhall sri
vectra c tapping noise from dash
vectra dashboard noise
vectra c clicking noise from dash when nothing on
