Results 1 to 10 of 20
Thread: smoke/dust coming from air vents
    Regular Member adfrodsham's Avatar
    lincoln
    Default smoke/dust coming from air vents
    when the fans are on a smoke or dust coming through air vents, with a wierd smell, checked what i can to make sure nothing trapped in intake. any other ideas?
    Surrey
    Heater fans I take it? Check the pollen filter?
    WGAF#5
    you say the heater is on ???
    maybe the heater matrix is beginning to burn out
    lincoln
    both hot and cold
    WGAF#5
    Quote Originally Posted by adfrodsham View Post
    both hot and cold
    you say a wierd smell - can you describe it???
    lincoln
    not burning smell, hard to describe, musty is the best word i think
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    i had this with my old car, my pollen filter had got damp some how (probbly jetwashing the car), try changing the pollen filter, its only three quid from halfords i think. or just give your original one a night in the airing cubord then give it a spray with fabreaze or somthing like it.
    WGAF#5
    needs an aircon decontaminant to kill the bacteria in the vents / pipes
    vx will charge you 30 - 40 quid you just need a can from a local parts shop
    put your aircon on full recirculation at high speed - put the can in and leave for 10-15 minutes (dont stay in the car as the cannister is carconagenic to kill the fungus/bacteria) then open the windows and run normally for aonther 10 minutes - should clear the smell and this should be done every 2 years
    hth
    regards
    Dez
    lincoln
    2 q's
    1, where is pollen fillter? is it under the wiper blade scuttle?
    2, how do you do the air con clean thing?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    my money is on the pollon filter m8, there is a flap by the bulk head on the passangers side under the bonnet....by where the wipers sit
  1. Ford Ka - hot air coming from vents on all settings
    By Caveman_nige in forum The 'Off Topic' room
    Last Post: 3rd September 2012, 00:27
  2. smoke coming from timing belt??
    By loom218 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2012, 18:57
  3. very little air coming out of vents
    By reeseandellie in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2009, 16:54
  4. smoke through air vents update
    By adfrodsham in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2009, 21:59
  5. Help smoke coming from dash
    By kitchcav in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2009, 21:24
electrical burning smell and smoke coming from air vents corsa c
