Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Breaking into reversing circuit...
    Default Breaking into reversing circuit...
    One for the electrical geniuses on here...
    I'm looking at fitting a reversing camera, plugging it into the CD70 colour screen as per the various discussions on here, and it all seems pretty straight forward apart form one thing - turning it on...
    Most people have used the function to add a video/DVD/PC function, and all these have an on/off switch which (as shown in various videos) acts as an interupt and automatically switches the display to the external input - in this case my camera.
    Most of the ones I've been looking at on eBay have a cigarette lighter as the power source, so that's easy enough to hardwire in, my only issue is how to turn the power on and off without having a switch...
    In a normal car, I'd just piggy-back it onto the power lines for the reverse lights - reverse gear selected, lights go on, power goes to camera and switches display over.
    However, as we all know the CANBUS would probably throw a hissy fit at me doing that (although if you can fit a redtop into it, who knows what's possible...)
    so, in a nutshell, anyone have any other ideas...? Or do we think that it might actually work as I've described it...?:
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    How about a micro switch on the g/selector?
    Quote Originally Posted by tyreman View Post
    Considered that - where is the switch for the lights to start with though? Is it in the gearbox itself...?
    Quote Originally Posted by Penfold101 View Post
    F23/F35/F40 transmision all seem to have a plunger type switch screwed into the selector lever housing so says the 'h manual' hth .............
    Aha - a genius, cheers tadders... I hadn't even thought of doing that, I shall go have a look later on...
    Surrey
    Mine and every other persons reverse sensors are on this circuit without a problem. I don't see feeding a camera as being a problem.
    Full Member
    Bristol
    just splice the reverve light power supply just like you do for reverse sensors
    Regular Member adfrodsham's Avatar
    lincoln
    or conect a wire to reverse light wire on rear light loom?
    Never thought of how people did parking sensors - cheers guys I shall experiment with this when I get round to it and see what happens...
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    cut a small bit of sheathing away and splice the joint, don't use a scotch block as this will make CanBus cry.....
    Midlands Mod Shop - NFFC.
  1. ddm open circuit????????
    By jpbroad1970 in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2012, 23:55
  2. fan relay circuit 3
    By cruicky27 in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 13:26
  3. anyone know how to tap into cig lighter circuit?
    By Morephun in forum Electrical & ICE (including SatNav)
    Last Post: 17th February 2010, 21:46
  4. Croft Circuit
    By Dunc in forum The 'Off Topic' room
    Last Post: 31st July 2008, 22:14
