Results 1 to 10 of 28
Thread: Instrument Panel Dials Not Working
    N.Ireland
    Default Instrument Panel Dials Not Working
    Hi All
    I am new to this forum and looking for some help. My instrument panel has stopped working, Rev Counter, Speedo, Temp Guage and Fuel Guage.
    I was cleaning the car and also under the bonnet since then it has stopped. I cant see any loose wires under the bonnet and wouldn't have the first clue where to check. Any help would be greatly appreciated.
    Mick
    Sunny Dartmoor
    That sounds like the CIM to me,apparently its behind the instrument panel and the plug come's loose,just need to push it back in,hope that helps.............
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    turn the key .... 'sorry, i had too'
    WGAF#5
    Quote Originally Posted by mick mcm View Post
    Hi All
    Mick
    did the odometer still work ??? - mine did this once having been left unlocked for about an hour - turned off engine took keys out locked and unlocked - restarted and everything works - thought for a moment i was back in my focus with the dodgy "watchdog" clocks again
    Surrey
    The plug behind the back of the cluster has a retaining clip on it so unlikely to be a loose cluster connector.
    Full Member gibbon7000's Avatar
    lincs
    This happened on my Omega once, turned out to be just a 3 amp fuse blown, worth checking before you pull ya dash to pieces. HTH
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    cleaning the car and also under the bonnet since then it has stopped. I cant see any loose wires under the bonnet.
    Mick
    Easy. ABS plug just unplug it, dry it out, you may have to put some switch/contact cleaner on it and I recon you'll have it sorted. The other guys are right to say CIM but if you were messing with water under he bonnet i'd go the the ABS plug. I had the same fault but intermittent, a quick clean and its worked for the last year or 2. HTH, keep us updated.
    N.Ireland
    Hi All
    Thanks for all the suggestions. Still nothing on the Dash after trying all these fixes. I have the car booked in the garage for tomorrow. Still under warranty so let them sort it.
    Again Thanks for the help.
    Regular Member CristianTM's Avatar
    ROMANIA, Eastern Europe
    Make a diagnose with OP-COM or Tech2. The results must be clear.
    CristiantM.
    Vehicle : SRi
    Mileage : 137000
    Sounds like the CIM then mate, £350 dealer fix, good job its still under warranty.
  1. Instrument panel
    By copperkettle in forum Electrical & ICE (including SatNav)
    Last Post: 7th June 2012, 15:02
  2. VXR instrument panel?
    By the_rocker in forum Styling
    Last Post: 17th April 2012, 12:19
  3. My instrument panel cluster is not working
    By bale541 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2011, 11:38
  4. Instrument Panel dials lit when external lights off
    By Street N in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2009, 23:26
instrument on opel vectra c doesnt work
vectra c ventilation fuse
