Results 1 to 8 of 8
Thread: 2.0dti Fuel Pump - Need Help Finding Cure
    Belfast
    Default 2.0dti Fuel Pump - Need Help Finding Cure
    Hi All,
    I have an 04 (pre-facelift) veccy with what a stealer is telling me is a defective fuel pump. Regularly the car just cuts the engine, and after diagnosis they have said it's most likely this but want between £1600 & £2k to fit a new one, and they've said this may not be the full fix, perhaps something else has caused it and may need more repairs... as you can imagine the few words spoken were a little bit blue and not repeatable here!
    Can anyone help me find someone in Northern Ireland who reconditions the Bosch VP44 that is in this lemon? I really dont wanna buy a new one when from all the reading I've done and from the feel of the car and some other little probs I've had, I think the pump is just f###ed electrically not mechanically.
    Anybody else experienced this fault? I'd be surprised if not given how many posts I've read with fuel pump probs...
    Appreciate any replies.
    Jonny B
    Mar 2008
    Liversedge, Westyorkshire
    this is the one reason why i keep paying lumleys for a warranty on my wifes car. they are well known to F**k up!
    although im loosing faith with my dealer. cant even track up the car properly!
    hope you find a cure, if you do, please leave a post. im sure it will help lots of folk!
    Regular Member madman's Avatar
    Mar 2009
    nottm
    between 1600-2000 to supply and fit a fuel pump? is that a pee take?surely thay cant be this much?
    Feb 2009
    wolverhampton
    Smile
    my 52 reg did what yours is doing and the dealer told me it was the fuel pump because there code reader comes up with fuel pump inop and it will also say crank sensor i just changed the crank sensor and touch wood it has been fine ever since and for the sake of £30 odd pound i wud try that first mate
    Bristol
    vectra 1985. I agree with you . Stealers say code reads pump error and in fact its the crank sensor. The garage I use has had 4 like these dealers say pump changed crank sensor.
    Regular Member redraptor_141's Avatar
    Sailing the High Seas on HMS Ark Royal
    Try a Website Called DieselBob. they usually have off teh shelf ones for about 400 quid. still expensive......but cheaper than the stealers. ithink you can send them yours as well all depends if its the hybrid ECU or not, if it is you might be out of luck on a recondioning, re-map, uprating.....pretty much anything lol (ive got one and i hate it)
    Belfast
    Thanks for the guidance folks, I'll try crank sensor first and see what happens, I managed to get a couple of people in UK to give me reasonable diagnosis charges but I haven't quite had time to get the pump checked for part code etc so I'm glad you've given me a different line of enquiry before I went to too much trouble.
    I'll post how I get on
    northern ireland
    Default bosch vp44 problem
    Hi,
    Just wondering if you sorted your problem? I'm having the same issue, bosch vp44 injector pump is ******ed (apparently!!). New one is £1400 so that not an option. Lots of people tellin me that i need an exact match as a replacement?? I spoke to a gut near Belfast who is telling me he can fix it by swapping out pump with a similar but not exact match and also swapping the main ecu and re-programming. He says he's done it in the past and is charging £250 for pump + £150 labour..
    Paul
  1. Vectra 2.0DTi fuel pump failure
    By Davyturner in forum Engine & Drivetrain
    Last Post: 29th January 2013, 17:33
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. How would you cure a air lock from fuel pump to injectors?
    By rollercoaster63 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd November 2011, 00:16
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. 2.0Dti fuel pump
    By wilf2312 in forum Engine & Drivetrain
    Last Post: 5th December 2007, 01:22
