Thread: VXR exhaust onto a 1.8 cat
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Default VXR exhaust onto a 1.8 cat
    im fitting a VXR exhaust onto my 1.8 ... using my old cat... im told i need a reducer...
    what is the size i need ? ... im thinking 64mm to 40mm ?? but not certain
    pls help
    shropshire
    anyone ?
    Cambridgeshire
    - Are you fitting the twin VXR exhausts or just one of them?
    - Have you got the centre pipe from the VXR too?
    shropshire
    Quote Originally Posted by parsco View Post
    Im fitting twin exhausts yes... and i have got the centre pipe... but no VXR cat
    Cambridgeshire
    Cool. I had the same kit and fitted it to mine.
    I used my existing centre pipe section and cut the end (that attaches to the CAT) and cut the end of the VXR centre section (that attaches to the VXR CAT). Your piece thatyou've cut off your (1.8) centre section will slip inside the VXR centre section and just needs to be welded together and bobs your uncle mate LINKY
    (This worked for me as I had already cut my centre section about with the Irmy Y piece that I had on it)
    HTH's mate, if you don't want to go down that route then you'll have to measure the parts to find the size of the reducer needed mate
    shropshire
    Thats great... if my old pipe slides into the new one then thats what ill do
    does the rest of it just fit easily ? .. i.e the boxes onto brackets ?
    Cambridgeshire
    Quote Originally Posted by Steven T Davies-Moss View Post
    Yep easy mate. Make sure you get it welded though mate then you can use the VXR centre section (with your new 1.8 head that will attach to the 1.8 CAT) as the head from your 1.8 will have the clamp attached to it.
    All the hangers are there mate and fits perfectly. HOWEVER, make sure you double check this BEFORE cutting anything
    shropshire
    Thanks M8... ur a star
    i was goin to buy a reducer... £18 delivered... but dont need to now
    thanks again
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    pics when fitted m8 .....nice choice of pipes
    shropshire
    Quote Originally Posted by big rich View Post
    will do... will be next week some time
  1. Exhaust hanger broken /rotted from exhaust.please help.
    By Dobs in forum Engine & Drivetrain
    Last Post: 25th January 2012, 21:06
  2. Duel exhaust - where to get a right hand exhaust heat shield
    By Innes in forum Bodywork & Interior
    Last Post: 29th November 2011, 00:47
  3. Fitting Dual Exhaust on single exhaust 2.2 sri
    By sdnatlst in forum Petrol Engine related
    Last Post: 1st February 2010, 10:49
  4. Where to buy oval exhaust tail pipes for signum exhaust
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 17:16
  5. Replies: 7
    Last Post: 22nd August 2007, 21:16
