Thread: ratling noise
    Regular Member yadziyad's Avatar
    London
    Default ratling noise
    hi i have a 2003 vec c 2.0 dti it makes a ratling noise when i press the clutch i was told that the chances are it was the dmf because of the high miles (118) so i got it changed with the clutch and bearings to but the noise is still there. has this happened to any one else. does any body know what it could be.
    Regular Member s1nglef1sh's Avatar
    Fife - Scotland
    Could be the drive shaft.... had this problem on a clio years ago. When the clutch was pressed there was a rattling/grinding sound. Turns out the gaitor/boot had perioshed and leaked and the sound was due to no lubrication. HTH
    London
    yeah it does sound like theres no lubrication. how can i find out is there a way witoout getting it all opened up.
    sorry dont know much about mechanics of it.
    Fife - Scotland
    If you're not savvy with a spanner I'd run it along to your local garage. Just ask them to check the drive shaft for leaks. Hope you get it sorted
    London
    Quote Originally Posted by s1nglef1sh View Post
    thanks alot for your help
    Fife - Scotland
    no probs
    London
    hi ive shown the car to a mechanic and he says that its not the drivetrain its the actual engine and that its worn out. and said i should tolerate the noise or replace the whole engine. what shall i do.
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. K&N noise?!
    By andylang in forum Vectra C / Signum Car Chat
    Last Post: 28th June 2012, 16:43
  3. M G ZR Noise
    By crispy007 in forum General Motoring Chat
    Last Post: 17th December 2011, 12:03
  4. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
