Thread: Adding Sub and Amp
    Kent, UK
    Default Adding Sub and Amp
    EDIT: Using Standard CDR2005 Headunit
    Well,
    My old sub's still sitting in the spare room gathering dust from my "boy racer" days and I've decided that she can come out of retirement!
    Been looking at the amp and it has a weird 4-pin connector for high-level inputs.
    I'm guessing that I need to find some sort of plug to fit this (easier said than done!) and then somehow connect off the speaker leads? Might be easiest just clipping a scotch-lock to the wiring loom for the speakers? (have to find out which cables are which first!).
    Then for the ignition wire, just jump off something on the accessories wire (prob do the cig lighter) as doesn't really draw anything.
    Running the power should be same as ever, hopefully the power lead will be long enough for a Vec!
    So, the only question is if anyone's done it already or if I've said anything totally stupid in the above?
    Adam
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If using as a monoblock take the sound feed of the 7th speaker.
    Kent, UK
    7th Speaker? Which one's that?
    I was forgetting that these cars aren't the simple FL, FR, RL and RR! What colours would I be looking for? Any ideas how to wire that to a weird high-input connector or could I get away with connecting it to the RCA's?
    Vehicle : SRi
    Mileage : 137000
    The 7th speaker in under the little grill in the front top part of the dash. Got the same headunit as you and an Vibe Amp/sub in the celler. Been thinking about this for a bit but the amp only has rca,s. I need the full boot for work so am thinking about making a box to put flush in the boot cuby hole. Think the vibe will be to hardcore for this though as its 600 w.
    Kent, UK
    As I'll prob be changing me headunit in the future, might be worth getting a one of these.
    You've gotta install it!
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    i have one of these if anybody intrested still in its box never been used
    Vehicle : SRi
    Mileage : 137000
    Yea been looking at one of these.
    Kent, UK
    Do you think it'll work okay?
    Vehicle : SRi
    Mileage : 137000
    Should do mate, but to get the full effect its a headunit change. But if your like me lack of funds come in to it so this would be a good way round.
    Kent, UK
    Yeah, Lack of funds is the main reason atm!
    My idea was to do this, I'll need to buy a new wiring kit and it gets me "half way" then I just have to replace the headunit and it's all done!
  1. Help adding photos on here
    By Telboy in forum General Chat
    Last Post: 10th April 2011, 11:48
  2. Adding Aux
    By Ginge7289 in forum Electrical & ICE (including SatNav)
    Last Post: 29th March 2011, 10:52
  3. ncdc2013 adding a sub and amp
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2011, 01:44
  4. adding a turbo kit to 1.8 sxi
    By wilsons 1.8sxi in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2009, 10:41
  5. Adding DAB
    By Blue Thunder in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2008, 21:57
