Thread: glow plug problem i think
    telford shropshire
    Default glow plug problem i think
    Hi,
    I have a problem with my 1.9 cdti vectra.
    On most mornings when the car is cold, the eml light comes on for between 2-5 minutes and then goes off as i drive around, i dont have any problems with cold start etc, but the light comes on every morning or when car is cold without fail. its not casuing me a problem as such but its just annoying not knowing what it is.
    Took it to the stealers, 2 or 3 times for diagnostics and they have told me its something to do with glow plugs.
    Anybody suffering from the same or know what it might be cheers.
    Feb 2007
    Leicestershire
    Had a similar problem with my Signum. Went back to the stealers 3 times in 4 days whilst under warranty. They told me to start with it was the glow plugs, then the relay, and finally a loose connection.
    I don't the stealers any more.
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    if you know what you're doing with a multimeter get it on the rail and see how much juice is getting to your plugs.
    Regular Member wilbur1's Avatar
    wrexham
    I've got the same problem and a few others on here have dont bother changing the glow plugs or relay i changed mine and the light still comes on it only started since i got the alternator changed so its got to have something to do with that.
  1. glow plug problem or relay??
    By bobsimes in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd August 2011, 20:16
  2. 1.9 DTi Glow plug problem
    By KBW137 in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 07:48
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
  4. glow plug
    By dominic32 in forum Engine & Drivetrain
    Last Post: 6th July 2009, 21:46
  5. vectra c 2.0dti glow plug problem
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 17th April 2009, 19:04
Tags for this Thread
