Results 1 to 10 of 13
Thread: gear stick knock ??
    Regular Member nigec's Avatar
    barnsley
    Default gear stick knock ??
    The top of my gear stick is somehow loose when you tap or slightly push it it makes a tapping noise, its not the whole stick moving down just the head, ive flicked off the part with the numbers on and theres a strange hole id suggest needing a special tool, any ideas or is it only the stellers that have this tool ??
    barnsley
    does anyone have any ideas its one of those annoying noises !
    Regular Member dlm71's Avatar
    Cheshire
    Mine does the same and it is the same year as yours! so i would be interested in the same
    barnsley
    Lets hope someone can help us out !
    Cheshire
    I have just worked out that it gets worse when it is hot like today, so i assume it must be a friction fit and the heat makes it loose! i think we might just have to put up with it! annoying as it is
    barnsley
    im sure there must be a way of tightning something up surly !
    Jul 2009
    Leeds
    I have noticed the same thing today with my 07 veccy. Its really annoying too but like you say i have only noticed it recently in this hot weather.
    Birmingham
    That used to happen to my dad's one, until one day I ever so slightly tugged on it and it came off in my hand. I think it means its about to drop off!
    Try giving it a pull, I bet it will come off!
    I ended up getting another 2nd hand one and that been on for a while without any probs!
    You could take it off and glue it back in?
    Bye bye Vec B
    - Hello Siggy!
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Had exactly the same issue with mine about two weeks ago. The knob just pulls off but it takes a bit of upwards pulling. Once it's off you can see the the splined fit. Refitted it and the noise returned about a day later. Took it off again and this time gave it a good clout with my hand, been quite since.
    Mine was the same, just pul it off, refit it and give it a hefty clout with your hand (or put a cloth over it and give it a tap with a hammer.
    Mine has been fine for months now.
  1. driveshaft/cv joint knock on acceleration or changing gear?
    By RyanNI in forum Engine & Drivetrain
    Last Post: 1st March 2012, 04:23
  2. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  3. Gear stick
    By Vectra King in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 23:54
  4. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
