Thread: Is this a mot failure or not
    newcastle upon tyne
    Default Is this a mot failure or not
    The other day i noticed the heat shield covering the back box had came off. The nuts holding it up were so rusted they snaped off. Can i just leave it off or must i repair it.
    Regular Member adfrodsham's Avatar
    lincoln
    dont think it maters mate tbh
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    Just remove it mate
    Newcastle under Lyme
    I thought this would present a fire risk but im sure the mot residents will be along to correct if wrong
    Quote Originally Posted by JSYSH466Y View Post
    I am a mechanic mate.if its insucre it will be advised irrc
    removal of the item is not a fail.
    Pm GARY3036(think thats it hes a tester
    chris
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i have removed lots of them before, mainy for annoying noises
    South Wales Assistant Regional Organiser davidjameswest's Avatar
    llantwit major
    i have removed some of mine before as they tend to rust around the bolts then rattle like mad, and never failed a mot by removing them as not all cars have them
    Ashington, Northumberland
    Take it off, it isn't an MOT failure as it isn't a testable item, however if it is that insecure that in the testers opinion it is quite obvious that it is in imminent danger of coming off, then he should advise you on it and even has the option to mark the advisory as 'Dangerous' if he thinks it may cause harm to other road users. So, either take it off or repair it
  1. Mot failure
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2012, 20:59
  2. DMF failure!
    By lofty in forum Engine & Drivetrain
    Last Post: 23rd February 2012, 11:30
  3. MOT Failure or Not?
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 14:50
  4. is it mot failure
    By the fisherman in forum Styling
    Last Post: 12th May 2009, 16:25
  5. DMF Failure
    By iainm in forum Engine & Drivetrain
    Last Post: 21st January 2009, 12:44
