Thread: sky remote programing?
    Regular Member adfrodsham's Avatar
    lincoln
    Default sky remote programing?
    i need the sequence and code to set up a sky remote to control a hitachi tv, i have lost the bit of paper that comes with the remote that tells you how to do it, pm with any details, cheers guys in advance
    lincoln
    done it now, any one else wants to do it, this web site is great
    http://www.satelliteonline.co.uk/pro...he_sky_rcu.htm
    Regular Member gromit's Avatar
    Cumbernauld
    Press tv then red button and select together until the light flashes then press tv then 0145 then press volume up. If the volume turns up then press select to store. If the volume doesn't go up then press tv then volume up again until the volume works then select to store. You might have to press volume then tv quite a few times before it works. Thats of the top of my head if it doesn't work then start from the begining again but it should work.
    The sky manual tells you to press tv then power but sometimes this method will make the sky remote turn your tv on and off but the volume won't work so press tv and volume up or down.
    If this doesn't help I will get a manual out of the van and copy it for you.
    lincoln
    cheers gromit,
    Blantyre
    ..........or go to sky active and do it from there
  1. Key Fob programing?
    By Sierra2 in forum Electrical & ICE (including SatNav)
    Last Post: 11th June 2012, 10:24
  2. AUX in on CD70 programing
    Last Post: 18th September 2011, 12:01
  3. Programing issues!
    By colalowe in forum Comedy & Humour
    Last Post: 11th March 2010, 01:28
  4. key programing question
    By iansfocus in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2010, 14:46
  5. key programing
    By johnturbo in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2009, 10:53
