Seen on other forums that they fit different FPR's to the V6's
Can this be done to the Vectra C?
also be interested to hear if this can be done
Sorry byt what is FPR?
Fuel pressure regulators?
Has this been done?
if there is no flat spot then there is no need but the 2.5 was supplied with a 3bar and had an in herrent flat spot so most changed to a 3.8 like i did which solved the problem and made the car much more drivable,
you can get 4bar regs as well and thats what id now change to by choice but i dont know what the 3.2 runs, if its less than 4 then ill be changing
I beleive t runs at 3.8 bar but might be put right?
