Thread: Rear fog lights
    Bridgwater
    Default Rear fog lights
    Just brought a face lift cdti elite hatch,and noticed that only the o/s/r fog light works, there is a bulb in the other side and I have tried swaping the bulbs from side to side but still no different.I've been reading on here that uk cars only have an o/s light.Has anyone got there n/s one working? Thanks in advance.
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    only the one side is wired as standard but i think its easy enough to wire up the other side
    Blantyre
    It is easy, 10 minute job,
    Bridgwater
    Is it just a case of running a wire from the live on the o/s over to the n/s?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Yep
    Regular Member gaz4d's Avatar
    Glasgow
    11 Post(s)
    Apart from cost cutting reasons, its also done for safety reasons as well.
    If you've only got one rear fog light illuminated, then whoever is behind you will be able to see your brake lights more clearly when you stop/slow down.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    PLEASE DO NOT DO THIS MOD
    Think of everyone behind you and how their eyes will hurt, and maybe not see your brakes lights come on and then rear end you.
    I hate rear fogs, as most people do NOT know how to use them properly.
    Bridgwater
    Thanks for all your replys.I did the mod yesterday.Every car i've had has had 2 rear fog lights,so I wanted this one to be the same.I'm not one of those who forget to turn them off.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Do you leave them on when there is someone behind you, or use them when visibility is more than about 100m???
    If so, then you DON'T use them correctly.
    I wonder how your insurance would be affected in the event of a rear end collision when you have them on, and the following driver not seeing your brake lights come on? Have you informed your insurer about this modification to exterior lighting?
    Please read my post above, and for your and everyone elses safety, remove the link wire and revert back to the OE standard which is done for a reason and has EVIDENCE to back up why it is done that way.
  1. Led Side Lights Fitted & 2 Rear Fog Lights
    By wardy23 in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 23:16
  2. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
