Results 1 to 10 of 20
Thread: Clay Bar Lubricant
    Blantyre
    Default Clay Bar Lubricant
    I have none left used last of it on the Mrs car , what can i use as an alternative ?
    Regular Member darko2301's Avatar
    Croatia
    water will be just fine although you can buy some lubricant separately, hth
    How do I use Auto-Clay?
    Firstly, wash your car thoroughly using a non-abrasive shampoo such as Auto-Wash.
    Using a suitable container spray water on to a small area of the paintwork and with a very light, fingertip pressure rub the bar back and forth. Ensure you keep the area well lubricated with the water so the clay bar glides across the surface. It is important not to use the clay bar on an un-lubricated surface.
    At first you will be able to hear the particles being pulled away from the paint and you will feel the resistance of the contaminents. However this will rapidly disappear and the bar will glide smoothly over the surface. The clay bar will have turned a dirty red / brown colour as a result of absorbing the contaminents. When this happens rub your fingers over the surface. It should feel as smooth as glass to the touch. If not repeat the procedure until all the contamination is removed. Finally wipe the surface area over with a soft terrycloth or microfibre.
    As the clay bar becomes soiled fold it over to keep the particles away from the paintwork. If the clay bar is dropped on the floor it should be thrown away as it dirt from the ground will adhere to it.
    The clay bar will be sufficient to treat the paintwork 4 or 5 times. If you prefer divide the clay bar into pieces before starting work with it. Then if you do drop it you haven’t ruined the whole bar!
    Blantyre
    Quote Originally Posted by darko2301 View Post
    I couldnt find megs lubricant, would water be ok ??
    Croatia
    i can't tell from my own experience, but according to one detailing site FAQ (from where the quote is) it is ok
    Croatia
    and yes, i've found you a meguiare's lube for 6.84 hth
    http://www.autobritedirect.co.uk/sho...89cd108de84f5c
    Newcastle under Lyme
    I used water you just need to use lots of it as I found it runs off very quick. My suggestion is spray and rub very small sections at a time
    Regular Member ade0303's Avatar
    doesn't quick detailer do the same job? Have you got any of that?
    Blantyre
    Quote Originally Posted by ade0303 View Post
    Dunno, need to go to halfrauds and have a look
    Cheers Mate, But need it today cant have the Mrs Car looking better than mine
    Croatia
    lol, i know that feeling
    if i were you i'd try to clay a small area with using water as a lubricant, to test how it'll work, just be sure to apply lots and lots of water and nothing can go wrong, hth
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    very little shampoo in water also does the trick, just a little mind as an extra lubricant
    Midlands Mod Shop - NFFC.
  1. Lubricant For Claying?
    By puppet in forum Detailing and Car Care Discussion
    Last Post: 17th June 2011, 21:11
  2. Gonna take you to a clay bar, clay bar CLAY BAR!!!
    By peppered in forum Detailing and Car Care Discussion
    Last Post: 7th September 2009, 21:11
  3. clay bar
    By sristeven1 in forum Detailing and Car Care Discussion
    Last Post: 31st March 2009, 22:02
