Results 1 to 10 of 11
Thread: changing front springs, price?
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default changing front springs, price?
    as above what would be a decent quote for an indi to change my front springs? I can do the rears myself just not too sure about the fronts
    Regular Member Dose's Avatar
    Falkirk/dunfermline/alloa
    £70? hour and a half labour...?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    about £50-80 depending where you go.....try and barter with them
    If you were closer it would be beer tokens
    Regular Member bizerk's Avatar
    EDINBURGH
    How you doing m8,
    Look into doing it yourself first,, it really is a piece of p1ss.
    Regular Member Phil MC's Avatar
    Kirkie
    I got a quote locally from a small independant garage in Kirkintilloch a few days ago, as I need all 4 springs changed, and was told £40 per corner!!!!
    £160 for labour???
    I went out and bought the tooling to do it myself at a fraction of that cost. I'll need to read up on how to do it, and have a tentative stab myself over the next few days .
    Newcastle under Lyme
    dont forget to have your tracking etc checked. Its as simple as take jack it up, take off the wheel, losen the bolts at the bottom and the single nut at the top in the engine bay, unscrew it all and take the suspension off, with the spring compressors tighten the old spring and dismantle making note to remember teh order everything goes back on, tighten the new spring and place on making sure to sit the spring correctly in its seat, now put it all back to gether and make sure all bolts are tightened. I changed the Clio front springs when they both snapped and it was spot on and didnt need doing but my old Seat was way out. It took me hours but this was only because it was french and still used metric spanners which I didnt have and had to find.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by JSYSH466Y View Post
    Lol dont forget all of the swearing and skinned knuckles in between
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    If you was down this end mate it would cost a brew!
    All you will need is a impact/windy gun for the top strut bolt a socket set and spring clamps
    I done it mate and am a novice with car's or was untill I got a Vectra C.
    Done full engine chages and all sorts now
    Somerset
    you can get away without using spring clamps on the front struts if you havn't bought them already. Just be careful taking the top nut off when the old spring is still in there.
  1. Supplementary Question on Changing Front Springs
    By Signumv6man in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2011, 16:12
  2. Spanner for Changing Front Shocks/Springs
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2010, 21:21
  3. measurements after changing springs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 19:03
  4. changing springs
    By kenny1zero in forum Handling & Braking
    Last Post: 30th June 2008, 02:12
  5. changing springs
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2006, 22:45
do i need to change springs with shocks vectra-c.com
