Results 1 to 10 of 13
Thread: car alarm
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default car alarm
    just this week my alarm has decided to have a mind of its own and go off for no apparent reason,all the doors and windows are closed and i don`t no why this is happening,does anyone no what might be wrong or what to check to get this problem solved.thanks in advance
    Derry
    Default car alarm
    Bump
    Wondering lonely as a cloud
    23 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Before you set the alarm by key switch OFF the internal sensors by use of the switch next to the HU. This is something thats happening to my mates Omega and this stops it probably faulty internal sensors well its a start.
    Derry
    how do i turn off the internal sensors m8?
    Full Member lizard's Avatar
    Oct 2006
    southampton
    12 Post(s)
    there should be a button next to HU with a little person on it iirc, its designed so if you have a dog in the car, you can still set alarm but disable internal sensor.
    Derry
    How do disable it,do just press it before i get out and lock the doors?I need to get it sorted before the neighbours start complaining.lol
    Oct 2006
    southampton
    12 Post(s)
    yes mate. might be faulty sensor, just a guess though.
    Derry
    cheers m8,i will give it a go,do i need to press it every time i lock the car,any idea where the sensor might be?
    6 Post(s)
    The sensors are right by the interior light. Yes, you have to press the button every time you exit the car when parking up.
    Probably unlikely it's the sensors though. The common faults are a failing battery back up in the power sounder, if the car is an estate - then the break wires in the rear glass, and the bonnet pin switch can also be a common culprit as well.
    Derry
    Its a saloon model m8,what do you mean by "a failing battery pack"?
  1. Car alarm keeps going off
    By si_hoss in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2015, 18:37
  2. Alarm keeps going off?!
    By Ben Chiles in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 22:26
  3. Alarm led?
    By Vectra Karl in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2012, 22:43
  4. alarm keeps going off
    By the fisherman in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2011, 01:22
  5. how do i get to my alarm??
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2010, 19:51
vectra c how to change power sounder site:www.vectra-c.com
vectra c car alarm keeps going off site:www.vectra-c.com
