Results 1 to 3 of 3
Thread: 2.0 dti glow plug fault???
    south shields
    Default 2.0 dti glow plug fault???
    posting on behalf of a fellow taxi driver, he has a 2004 2.0dti vectra and sometimes if he turns it off shortly after starting from cold it just turns over and there is a buzzing from a silver unit (glow plug relay??) under the bonnet positioned near the battery on the right hand side of the engine bay as u look at it.
    Also the glow plug light only comes on when first starting and then not even a flicker (mine comes on for a split second even when warm)
    any ideas?
    Apr 2009
    stockton-on-tees
    alright im having similar problem with my 2.0dti i had 2 fault codes coming up P0400 Exhaust Gas Recirculation Flow Malfunction and P0380 Glow Plug/Heater Circuit Malfunction
    i replaced the glow plug relay the silver box £30 from vauxhall and it had got rid of the P0400 fault code going to change leak off pipes and clean egr valve this weekend help please
    Full Member Big Sig's Avatar
    the glow plugs only come on if needed, not all the time
  1. Spanner light glow plug fault
    By drewdrewuk in forum Engine & Drivetrain
    Last Post: 25th January 2013, 12:53
  2. Glow plug fault
    By Jekyll & Hyde in forum Engine & Drivetrain
    Last Post: 19th May 2011, 22:27
  3. glow plug general fault.
    By woodspsx1 in forum Engine & Drivetrain
    Last Post: 7th April 2011, 07:53
  4. glow plug fault?
    By wilbur1 in forum Engine & Drivetrain
    Last Post: 10th February 2011, 19:00
  5. Glow plug removal + elec fault
    By mr.c72 in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2010, 22:23
zafira dti glow plug faulty
