Thread: Cambelt Replacement.....
    Merseyside
    Default Cambelt Replacement.....
    My CDTI (150) Signum has now covered almost 53k miles.
    Does the belt need replacing at 60k miles or 80k miles?? I've heard different answers in relation to this.
    What sort of cost am I looking at for an independant garage doing it - also, what does the cambelt kit cost from a Vx stealer??
    Full Member Big Sig's Avatar
    I think the book says 80k or even 100k but I would give a lot of consideration of getting it done at 60k due to the hassle of premature failure that can happen, not common but you never know. For me its better safe than sorry! Also, there is a time eg.4 years or 40k etc.
    Also the search button will give a lot of opinions on this chestnut
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the book says about 110 thousand miles, i have done one the other day at work and took about 2.5 hrs
    Regular Member Readster's Avatar
    Plymouth
    I have had some confusing messages about this subject. A VX dealer has told me that 1.9 (120) don't need a cam belt for 10 years / 100 miles. ECO 1 contradicts this but, the VX dealer is adamant that VX have extended the service intervals...
    The same extension applies to valve clearances btw.
    So, basically unless you have a problem ie a visual examination shows damage / wear it doesn't need routine changing.
    'servicing' in VX speak is oil & filters & visual examination.
    Interesting eh.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    The book does (like glynn says) state 110k or 10years for cambelt, however there's been so many problems with VX engines that its a risk leaving it anywhere near that long. Its an expensive game if u lose the gamble and VX wont want to hear about it. My VVT just gave up at 43k and slipped the timing so they are changing the belt etc whilst there, it should give extra piece of mind, I was going to change it on the 60k service, seems a good compromise to me. Kits are around the £70 to £80 mark I believe and fitting/service will change depending on what u want done, best just to phone round and ask m8.
    Quote Originally Posted by Readster View Post
    Interesting eh.
    I have to disagree with the visual check on a belt. It may not always be possible to see any potential failure points. Where I work we have steel rienforced endless belts specially made, they still snap!
    For £250 odd its worth it for the peace of mind. Whats a new engine going to cost?
    Plymouth
    I agree BS. This is out of the VX dealers mouth
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    2 VX dealers both told me that its officially 100k miles on the cdti-150, however common sense tells me that time would need to be taken into consideration. IOW its possible that a cam belt on a car that's covered 100k miles over say 2 or 3 years will be in far better condition than the cambelt on a car that's only dont 20k miles over 10 years.
    I would think it a good idea to change it around 70-75k miles to be on safe side, and more importantly when deciding to change it the age of the vehicle.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Had mines done at 67k, and I thought that was really late, although it says 100k, and vx have apaprently dropped it to 80k, best not to let it go over 60k.
    Gazza4
    Regular Member benny's Avatar
    Feb 2006
    dudley
    seems there going to drop the interval but i would say get it done along with the water pump at 40k 4 years .... the 1.9 is turning out to be as bad as the old 2.0xev was in the vec b ..vx techs love them loads a work to be done .....money to be made so to speak ...
  1. v6 turbo cambelt replacement,how much?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2012, 22:45
  2. 1.9CDTi 150 Cambelt Replacement - Big Problems
    By Pete B in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 12:48
  3. 3.2 vectra cambelt replacement
    By brickit10 in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2009, 22:49
  4. 1.8 cambelt replacement?
    By bloodworm in forum Engine & Drivetrain
    Last Post: 31st December 2008, 20:28
  5. 2.0T Cambelt Replacement Schedule
    By Rebellion in forum Engine & Drivetrain
    Last Post: 15th June 2008, 04:20
